New attachment - flush hydraulic oil?
   / New attachment - flush hydraulic oil? #1
cold1313
Gold Member
Northern, Ohio
Kubota M4D-071 Kubota F3990
I have a new implement coming in, with two hydraulic cylinders.
Should I flush / drain out the oil that comes in the cylinders, to not contaminate my Kubota hydraulic oil?
   / New attachment - flush hydraulic oil? #2
If it's new the cylinders should be clean (and are unlikely to contain oil).
If it's used, then there could be nasty watery old oil in them. You can disconnect hoses, drain the cylinders and inspect the oil.
It's brand new but has been cycle tested at the factory, so it will have some sort of hydro oil in it
   / New attachment - flush hydraulic oil? #4
I would not think there would be enough fluid to cause any issues. I would just use it.
   / New attachment - flush hydraulic oil? #5
I would (and have) for used cylinders. Haven't bothered on new cylinders. Factories should be testing with reasonably clean decent oil. I'd likely even do it on a rental impliment.
May be overkill, but a couple bucks of oil & 15 minutes of my time is worth the piece of mind. Even if dirty oil isnt actually going to cause any problems. It doesn't take much to mess up a HST tranny.
Right...I know it's overkill but I'm tempted to open the quick connect fittings and try to manually cycle the cylinders to see if I can get any foreign oil out of it. Overkill but was worth asking before I just plug and play.
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A56435)
2025 Mahindra 6075...
2010 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2010 Chevrolet...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
LOT: Assorted Hammers (A59076)
LOT: Assorted...
