New and yup, ANOTHER log splitter project
   / New and yup, ANOTHER log splitter project #11
The way you would calculate how much force you would get with multiple cylinders is to multiply the force each cylinder has times the # cylinders However you also have to consider that when you mount them if they cock the slide and make it bind you will lose some or all of that. I have seen one built with 2 cylinders side by side and it would sometimes bind so bad it would stop itself halfway with no block. From what you describe the wood you will mostly split, you may get by with one cylinder for about 12 tons, if you put the wedge on the ram then you can have the ram retract power get any block that gets stuck on the wedge back off, which is by far the worse case scenario when you are under powered.
Going by your first post your best bet may be to use the one cylinder, make it as cheap as possible and be happy with whatever it will do with 12 tons. Just go into it understanding that you are building a 12 ton splitter, with splitters the tonnage is a general yard stick, the higher the tonnage the more it is going to cost to buy or build, period. The only way to cheat that is to find high tonnage parts for sale at a low tonnage price.
I have seen 12 ton units do a nice job on wood like you have described, the problem would come if you tried to compare your unit with a 35 ton unit. Point is, if your gonna need a 35 ton unit, then wait until you can find a 4 cylinder and such that you can afford (Ebay, Craig痴 list, local auctions etc). But if you can truly make do with, and want a 12 tonner then go with what you have and build it simple, and fast.
   / New and yup, ANOTHER log splitter project #12
That's Ok, I am old and tired,
Take heart....you look a lot better than I do!!!
At least you got hair.....
   / New and yup, ANOTHER log splitter project #13
I am in the process of building a 2 cylinder, guillotine style splitter to split standing pieces. I have 2 4" cylinders and am using the sides off an old in floor garage hoist for the frame. The only problem I see is a bottom/floor piece that is strong enough with out having to elevate the wood to sit on it. I am thinking 1" flat with a back lip for extra strength. It always seem strange to have horizontal splitters that we either struggle to put the sticks up on, or contrive some hoise system. This to me is the best method of using 2 like cylinders... parallel.
   / New and yup, ANOTHER log splitter project #14
if your gonna need a 35 ton unit said:
how do you get 35 ton w/ 4" cylinder?
sizzami;1747947[B said:
]how do you get 35 ton w/ 4" cylinder[/B]?
Get a Troy-Built. :D
Thanks again for all the ideas.
I still might try this, because 40 bucks for another cyl is no big deal cost-wise. I figure they'll be one on top of the other and bolted to a 1" rear plate with a 1" pusher plate. It might cock to the top or bottom, maybe, I'll try to keep the rods as close to center as possible. If it does, I'll just remove and modify back to one, or make a longer slide for the pusher. I'll see what happens.
Speed is not much of a concern, I only split roughly 2 cords a year. Besides, splitting 2 cords keeps me busy for a weekend, and out of the wife's hair. :p
   / New and yup, ANOTHER log splitter project #16
15 ton is all you are going to get at 2500 psi, and that is with the log splitter in the slow mode. High pressure, low GPM.
You have to go to a 5 in to get 49,087 lbs, = 24.54 tons
   / New and yup, ANOTHER log splitter project #17
Yep. 15 is about all a 4" will do. Why the builders get away with claiming 20 ton for a 4" and 27 ton for 4 1/2" I don't know. Simple math says they are way off base. Even with the valve bypass set for 3,000 pounds (not recommended) they don't reach those nubmers.
Harry K
   / New and yup, ANOTHER log splitter project #18
<snip>
<snip>
I, on the other hand, cannot see crawlign around on my knees trying to maneuver a heavy round on the ground. I have to get whatever I am splitting on the truck to haul it home anyhow so getting it on the splitter is not that big a deal. No deal at all if I split direct from the truck. My old homebuilt was too low and it only took a few minutes for the back ache to begin. I raised it 9" and it became a whole better world. Just the thought of working rounds 'on the ground' brings back memories of back pain.
Harry K
   / New and yup, ANOTHER log splitter project #19
I think the exagerated ratings have led us to believe we need a bigger splitter than we do I have built a PILE of 15 ton splitters and you just dont find rounds under 20 inches long that they wont push through a single sharp wedge.
   / New and yup, ANOTHER log splitter project #20
Harry K
I'd agree if ur hauling, but my plan is to put it on a 3 point and just back up to the piece to split. I split some 24" stuff, post oak, and I have been rolling them into a bucket and dropping them in mass into a dump trailer til now. All that size are split the next year ( seasoned) at the pile. I'd disagree on the effort. Flipping a nice sized piece of oak on end is not the same as hoisting it onto a horizontal beam... not even close.
I have been building fires in a central wood heat source since I was a kid 40 years ago, and I just like to use wood now as a backup source until we get to freezing, or even say 40. Nothing warmer on a cold day than wood heat.
I have made 6 pick up bed trailers that I keep full beside the two furnaces. But to each his or her own. What ever works, but I am not into DCs that much.
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
STORAGE FEES (A59575)
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
Mini SUV (A59231)
Mini SUV (A59231)
