New, and looking for help
   / New, and looking for help
Does the rotation for the seed plate come from the rear wheel via the two flat bars? I'm not familiar with this planter and trying to understand.
Welcome to TBN!
Exactly. The flat bars turn like an old. Locomotive and turn the gear attached to the seed plate. I'm puzzled too. I'm somewhat mechanically inclined and I see no way to adjust it. :(
   / New, and looking for help #12
The bell cranks that are pinned to the axles to attach flat bar were probably offered in different lengths, by swapping different throw length from front to back you could change seed spacing.
Thank you so much. Now to try and figure out a place in the world that sells something like that..... And what do you think? Longer armed? I would think shorter would be faster spinning, thus making the seed plate spin faster.
   / New, and looking for help #14
Need small on drive wheel, long on driven end. Should be easy to make with several holes on each end so you can adjust.
   / New, and looking for help #15
Surplus Center sells sprockets and roller chain pretty cheap if you wanted to go that route.
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2020 Kinze 3505 High Speed 6/11 Planter (A56438)
2020 Kinze 3505...
