New 60 hp Boomer
   / New 60 hp Boomer #1
joes_427_vette
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
New Holland recently came out with a 60 hp version of the boomer. Does anyone know where they got the extra 5 hp ? I have read the engine from the 45 is the same as the 55, only with the addition of the turbo. I am wondering if the up'd the operating speed and maybe more fuel flow to get the higher stats. I think they dropped the draft control on the three point possibly as a cost saving measure. The axle casting may also be the same as the 55. Wonder how the base price spread between the two.
   / New 60 hp Boomer #2
Engine speed is 100 rpm's more and the price difference is about $1,500.00 over the 55.
   / New 60 hp Boomer
So with new stickers and a little encouragement from the governor I too could have a $1500 upgrade. Must be a pretty good engine design that the engine can go from 40-60 hp ( 50% increase ) with little change in the basic components.
Froggy, did you hear they are draft control delete also ? Unless you were plowing it would be of little use I guess.
   / New 60 hp Boomer #4
I've always liked turbo engines because of their wide performance band. If you don't need the power, you don't get up on turbo boost and the engine "putts" along at it's low power configuration. When you need the power, it can provide that also after a little lag to get the turbo spinning.
New Holland is really getting it's money out of the N844 design. The unstroked and unturbocharged engine is the 40 hp model. The long stroke is 45 hp, and the turbo model is 55 hp. It would seem that a little tweaking on the pump and a few more rpm is just the ticket for a little more power in the 60 hp version.
   / New 60 hp Boomer #5
yeah -- I have that 45 ....and really enjoy those longer strokes ....:eek::p:rolleyes::D
   / New 60 hp Boomer #6
Really wished NH would add the hst option to these larger hp tractors. They would really give JD and Kubota a "run for their money".
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
7ft Dozer Blade Skid Steer Attachment (A51573)
7ft Dozer Blade...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
New/Unused 72in Quick Attach Rock Bucket (A51573)
New/Unused 72in...
