New 5155 synchro grind
/ New 5155 synchro grind #1
austinarant
2022 Mahindra 5155
Hi. Just recently bought a new 2022 Mahindra 5155 4x4. I’ve put 12 hours on it so far. About 1 out of every 4 reverse shifts on the synchro lever it kicks out of gear and horrible grinding sound. Hasn’t done it in forward at all only reverse. I messaged the dealer I bought it from and he says “I need to shift hard into reverse”. Well I’ve tried that and sometimes it goes no issues and sometimes it kicks out and grinds gears bad. Any suggestions before a warranty claim?
/ New 5155 synchro grind #3
I adjusted the clutch linkage to spec, which seemed to help. I'm going to check the shift linkage tomorrow to see if there are any adjustments to be made there. Is it possibly an assembly issue? If you don't mind my asking, where did you buy your 5155? I got mine from Knoxland Equipment in Warren, NH.
Got mine from ENC Mahindra in Leland, NC. Definitely could be an assembly issue.
Thank you very much. I will try this today!
2015 Freightliner (A64119)
2015 Freightliner...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
159119 (A60430)
159119 (A60430)
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
