New 5105 Clutch problem
   / New 5105 Clutch problem #1
andrewj
Platinum Member
South Carolina
JD 5105
this happened today - I can't figure out what happened, but the malfunction is definately internal in the transmission. Seems the wet disk stays ingaged - depressing clutch pedal won't dis-engage the clutch. Haven't had it more than 8 months, so I hope dealer will take care of me. I will keep you updated.
Anyone else here have that problem?
   / New 5105 Clutch problem #2
Have you checked to see if a wire has been pulled off of a solenoid under the tractor?
Hmm - very possible - but my tractor is a gear driven tractor, not hydro - you still think I should look for a disconnected lead?
I have a wet disk clutch. I don't know if it is mechanical or hydraulic.
any help appreciated.
   / New 5105 Clutch problem #4
Most tractors with wet clutches have two clutch packs that are activated by solenoids. I would check to see if any wires are off.
Update - it is mechanical, not hydraulic, and it is a dry disk,not wet. They are coming to get it and I'm sure they will take care of it. Will update you guys when I find out what broke.
   / New 5105 Clutch problem #6
What broke?
OK, here goes as to the official explanation:
There is a threaded rod with nuts on it that controls how the pedal affects the clutch. It the length of the rod is out of whack, no workie. The head mechanic at the dealer walked me through some obvious checks while on the telephone. He suspected a clutch linkage adjustment, and he asked me to describe what I saw - and based on my eyes and his brain he was not sure. They sent the salesman (who has become a pretty good friend, real nice guy and all that) to pick it up. They had it fixed the following day, turns out the clutch linkage had worked itself out of adjustment. I appreciate all the tips here, as i have never owned a tractor before and so much is a learning experience.
   / New 5105 Clutch problem #8
We will have to stay in touch. I put in my order for a new 5105 yesterday. Am expecting delivery in three weeks.
I am getting the loader, joy stick, bale spear, and fixed pallet forks. This replaces a 1960 MF Deluxe 35.
Do you have the loader, and if so, how does the shuttle perform in loader work?
   / New 5105 Clutch problem #9
Does your 5105 smoke much at start-up?..My 5205 does..JD says this normal for this engine..5105 & 5205 have same engine..Thanks
   / New 5105 Clutch problem #10
Please let me know if your 5105 smokes much at start-up..My 5205 does..Thanks
1986 Toyota Pickup Pickup Truck, VIN # JT4RN67S8G5041038 (A48836)
1986 Toyota Pickup...
2015 Ford F-150 4x4 Pickup Truck (A48081)
2015 Ford F-150...
2012 Chevrolet Express Van, VIN # 1GCWGFFA0C1114930 (A48836)
2012 Chevrolet...
(1) 10ft Tarter Livestock Panel (A48837)
(1) 10ft Tarter...
2020 CATERPILLAR 299D3 XE SKID STEER (A50458)
2020 CATERPILLAR...
Case M4K Rough Terrain Forklift (A48837)
Case M4K Rough...
