New 5055E PTO lever Hard - Impossible to engage
   / New 5055E PTO lever Hard - Impossible to engage #1
JMHTX
Montgomery, TX
2014 John Deere 5055 E Cab
Hello,
I have a brand new tractor, and will probably be talking to the dealer about this. But
I thought I might get thoughts from here as well see If I'm missing something.
Here is the deal:
New 5055E Cab Regular gear 9 x 3 tractor running and in Park Clutch depressed
Try to move PTO lever forward to engage PTO it makes contact and begins spinning the mower blade
(Clutch still depressed) and lever will only move an inch or so as soon as I let go
it disengages I cant push harder on the lever or it will bend. Tried the same thing with Tranny in gear
same deal.
Thoughts - Advice ?
Jon
   / New 5055E PTO lever Hard - Impossible to engage #2
Possibly control cable is dry,maybe need lubrication.
   / New 5055E PTO lever Hard - Impossible to engage #3
Your profile says you have a cab. If that's true, your pto should engage by pulling-up a yellow knob to the right of your seat.
There is also a T-shaped handle that changes between 540 and 540e.
I'm not aware of a lever to control PTO in the 2014 cab tractors.
   / New 5055E PTO lever Hard - Impossible to engage #4
ePTO only available on power reverser. Have you tried with it in neutral? Maybe won't go in when tractor is in park? His has a lever to the left of the seat
Brett
   / New 5055E PTO lever Hard - Impossible to engage #5
My mistake; I thought the 9x3 was the power reverser.
My manual says that with the shuttle shift you have to rev the RPMs to 2400 before engaging the PTO.
   / New 5055E PTO lever Hard - Impossible to engage #6
I would call the dealer something is not setup right. I have 9X3 on 5210, while not a 5055E I can engage the PTO at any speed. I just make sure the attachment will not pull the engine down. While you can slowly engage it, why would one want to have the engine running at full speed, if you push it to fast it could be hard on the attachment.
Before disengaging the PTO, I slow the tractor down, let is spin at lower RPM for a minute or so before disengaging. Maybe all wrong, but that is my 2 cents.
If you do contact dealer, I would be interested in knowing what is shared with you.
   / New 5055E PTO lever Hard - Impossible to engage #7
I would expect that Tx Jim is on the right track.
I suspect that your PTO works like my 2011 open machine. The PTO is independent, and the lever you are moving operates the PTO clutch pack. It doesn't care if you are in gear, neutral, or park. The foot clutch has no effect on the PTO. If the engine is running, and you move the lever, the PTO should run. Where it's a new machine I would definitely have the dealer check it out. It should remain engaged, and travel should be a lot more than one inch.
   / New 5055E PTO lever Hard - Impossible to engage #8
My thoughts are it is out of adjustment. Adjusted one once on a 5105 and got it too tight to start with. Loosened it up and all was well. Being new....dealer needs to correct. Good way to create paper trail of the issue too.
   / New 5055E PTO lever Hard - Impossible to engage #9
I agree, it is probably adjusted too tight or something is wrong with the linkage. The adjustment is very easy to do, but I would have your dealer come check it and you can watch him adjust it. Then in the future as the clutch wears, you will know where to adjust it. THere is a clevis on the end of the engagement rod that can be shortened or lengthened. One or two turns makes a big difference in how tight the lever operates.
Thanks for the responses guys. I will be talking to the Service Department tomorrow. I will post up
what happens tomorrow evening.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
Tree Boom (A50322)
Tree Boom (A50322)
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2012 BIG TEX PIPE TRAILER (A50854)
2012 BIG TEX PIPE...
