New 5055E PTO lever Hard - Impossible to engage
   / New 5055E PTO lever Hard - Impossible to engage #11
My PTO selector lever [mid/rear] didn't work right when machine was delivered - factory didn't have a snap ring installed correctly.
[dealer picked up / fixed / brought back / with no cost - or effort on my part]
I was initially under the impression it was a cable issue.
This was on a 3046r, but just wanting to stress calling the dealer asap since the factory can have a bad day too.
Service manager from my dealer is scheduled to be here in the morning. I will let yall know what happens.
Thanks again for the responses
Problems solved, Tech came out today, Linkage - something was way overtightened under the tractor Loosened it, adjusted it.
Ready to rock and roll.
   / New 5055E PTO lever Hard - Impossible to engage #14
:thumbsup:
   / New 5055E PTO lever Hard - Impossible to engage #15
Good news! I suspected that was the issue due to having an issue with that adjustment myself. My issue involved my 6' rotary cutter "slipping" under load/in tall grass. I was afraid my PTO clutch was slipping or failing. I even swapped cutters to be sure it wasn't the cutter somehow. After posting on TBN and reading through owners manual I learned how to check the adjustment. In the process of adjusting I set it too tight initially and had to readjust to get it where it needed to be.
One more reason I like the "simple" design tractors.
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2318 (A58376)
2318 (A58376)
20FT X 20FT ALL STEEL CARPORT (A58214)
20FT X 20FT ALL...
2018 Vermeer BC700XL Woodchipper (A57453)
2018 Vermeer...
Unused 12x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 12x20...
