New 4410
/ New 4410
</font><font color="blue" class="small">( I have yet to get the rear facing work lights on mine yet. I plan to soon. Are the rear facing lights John Deere? By chance, do you have a part number? /forums/images/graemlins/laugh.gif )</font>
The rear lights are Deere as are the front.
Rear light LV910502 $38.00 Includes just one light
Front Light LVB25023 $50.00 Includes two lights
ROPS Light Brush Guard LVB25236 $38.00
You need the Brush kit to mount the front lights. All lights route wires inside the ROPS. At bottom of ROPS there is a purple and black wire to connect light. There is only one set of connectors on each side of the ROPS. If you add the rear lights and then later want to add the front you need to use a wire splice to tap in. I made a small Y using crimp on connectors so I didn't have to splice in. The connectors are bullet style. It should also be noted that wired this way all lights are on or off. I'm looking at adding two switches so I can turn the front and lights on when I want.
Craig
/ New 4410 #12
Dealer mounted my front lights without the brushguard. They keep turning all over the place. Not a real help. Are you sure the brushguard is "required"?
/ New 4410
JD lists the brush guards as a prerequisite to the front lights. That doesn't mean you couldn't find a way to mount them without the brush guard.
$38 seems a bit high for the metal straps that make up the brush guard kit, hence some have optioned for there own lights and mounting methods. Others might want the OEM look or just idea of a simple bolt on kit.
Craig
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2018 Trail King Lowboy (A61307)
2018 Trail King...
2025 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 Hydraulic...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
2011 DOOSAN G25KW GENERATOR (A60736)
2011 DOOSAN G25KW...
