New 4310 and have questions!
   / New 4310 and have questions!
Hi Goodguy
Your procedure for removing is what I ended up doing through trial and error. The problem I had was the rockshafts wouldn't raise at all, even with the hose hooked up. It finally did but I think it was stuck because it had not been exercised. I really don't know but cleaned the rockshaft filter and everything works fine now.
The lights are a great idea because I do occasionally move snow in the dark.
I appreciate the info on the manuals.
Thanks, Tom
   / New 4310 and have questions! #22
The 4310 looks great! That's a real nice setup. Doesn't look like it was ever used. /forums/images/graemlins/cool.gif
Hi JayC
Only had 24 hours on it when I picked it up. Had to buy a new battery for it (discharged and frozen solid) and drove it home. About froze to death because I was 15 miles from home and it was 15 degrees out. Was worth it though...
Hate to drone on but anybody know about "break-in oil". Before I bought it, this tractor sat for over a year in an outside covered shed. One of the first things I did was dump the oil and change the filter. It had 25-28 hours on it when I changed the oil because I just felt uncomfortable leaving the original oil in there. A friend said there was probably break-in oil in there and I should have left it until it hit 50 hours.
The manual indicates an oil change at 50 hours. Is 25 hours sufficient to break in the rings etc or should I put new break-in oil in it and run it for another 25 hours or so? I thought break-in oils were old school stuff but I don't know much about diesel engines. Does anybody know if JD puts break-in oil or regular oil in the engine. Is this a problem or am I just an over-protected JD owner? /forums/images/graemlins/confused.gif
   / New 4310 and have questions! #25
While a specific break in oil might be good, I would have changed that oil, too. And a good oil should be fine...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2021 Fleco DX140 24in Digging Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
202483 (A54757)
202483 (A54757)
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
