jsboening
Stop rubbing it in!
			I need to add some angle iron to the stabilizer feet to help secure it.
It would drag whole tractor with park brake on and loader on the ground when rolling bucket!
Do you guys have sub frames for your BH's, I have a 48 and it was not standard equip when I got it, now I hear they strongly recommend it for the 48.
Or did they redesign the newer BH's so a sub frame is not required?
JB.
JB.
here are some pics - will explain them in next post
Nice rig. I have that same loader/hoe set-up on 3320 e-hydro.
Overall, it's a nice rig, except it smokes blue on cold start-up, LOL. 375 hoe is similar to 447 but fits cab tractors. I've stumped out some pretty large stumps with that hoe. Stumps are pretty demanding and small hoes aren't really built to dispatch them in rapid fashion. The little 375 gets it done with some patience and a good sharp axe or two on hand. Biggest stump I've done was a double trunk hardwood measured 36X24 at the solid wood cross section a foot above ground level. I took this tree down (it was diseased, 10 ft from house in front yard, overhanging roof) limb by limb from above with tractor, stout rope, and chain saw. Left 20 feet standing on both trunks. Hoe dug all around it about 10 ft diameter and 5 feet down close in, cutting all the large roots as required close in with an axe. Filled the hole on one side before yanking it over with the tractor. Took all it had in that tractor to pull that tree over. Down sized the huge remaining stump and root ball with the hoe. Chain sawed the trunks short to the stump. Chained her to the hoe bucket. It was all that hoe/tractor wanted but it finally picked it up with several attempts and hauled it to the woods. Large and difficult project. Small rig did a great job.
