3-Point Hitch New 3110d owner - whining noise from transmission, 3 point not staying up
   / New 3110d owner - whining noise from transmission, 3 point not staying up #21
I just drained my JD303 spec hyd fluid out and installed transmission fluid.. I hope it will handle the heat a little better without thinning out.. I have been having problems with my hyd fluid thinning out while working the tractor hard in the extreme heat , creating very little flow to operate the loader, and the tractor it's self is very slow to respond
I think it will make it worse to be honest. ATF is usually 10W20 and I.m pretty sure the hydro/trans is thicker than that without researching it. It will be better in the cold weather for sure but not the heat. Although my YM14 runs J spec ATF fluid which is thinner again and it's fine in the hot weather. I guess all you can do is see what it does :2cents:
don't sound like a whine to me.. sounds like something in the clutch area...A bearing maybe ? Adjustment ? If you can wait that long... I'll start mine up in the am, but I don't believe mine makes that noise.. from that vid, sounds like a grinding noise to me
Thanks, I really appreciate it. I went and grabbed a video this morning going through with range 2 and 3 and switching the powershift gears
Yanmar gear shift and driving - YouTube
It's in neutral - both range and powershift. Thanks
   / New 3110d owner - whining noise from transmission, 3 point not staying up #24
I saw on a bucket or traveller Hydro fluid/trans fluid (from TSC) it said 10w20. Maybe it's measured different than other oils....kind of like gear oils..it's a different scale maybe?
   / New 3110d owner - whining noise from transmission, 3 point not staying up #25
Fellow tiger fan I see :) I was like is this guy filming me? Your related videos I have done the top two that showed up there. Hahaha
To me it doesn't sound that bad. But I don't have anything to compare it to as I don't have a PS a D haven't driven one. But I they JD 855 (yanmar painted green) i have driven it seems to have that much or more wine in it.
   / New 3110d owner - whining noise from transmission, 3 point not staying up #26
ok , your tractor whines more than mine. In the first vid you posted sitting there in neutral, and just letting the clutch out.. Mine doesn't make that loud noise at all
   / New 3110d owner - whining noise from transmission, 3 point not staying up #27
Did you ever check your clutch adjustment?
   / New 3110d owner - whining noise from transmission, 3 point not staying up #29
I did not. Where would I do that? Thanks
It's very difficult , so please pay close attention. Place you index finger on the clutch pedal and press downward and see if there is approximately 1/2", or really any "play" in the pedal before it hits resistance.
Yes, about 3/4" to 1"
I did the fluid change and still have the sound so I'm assuming it's an adjustment need
2018 KUBOTA SVL75-3 SKID STEER (A52709)
2018 KUBOTA...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
CORN SHELLER MOUNTED ON WOOD BOX (A58374)
CORN SHELLER...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
