NEW 2610!
/ NEW 2610! #21
Hmm, Mine does not have this rubber insert either and its a 2008. I've lost 4 bolts that tensions the rops. They always tend to rattle loose and out. I need to get some more but this time I'll double up on the nuts to lock them in. I'll look into these rubber pieces.
/ NEW 2610! #22
Just drill a hole at the start of the threads of the bolt and insert a cotter pin or a set pin (after bolt is installed)... This way it can only loosen so far before the pin stops it from going any farther and falling out. Or a real easy way... After installing the bolt, just take a center punch and hit the last few threads, that should be all that is needed to stop the bolt from coming out "easily".
/ NEW 2610!
On my old 2310 I used rubber garden hose gaskets on the ROPS bolts to quiet the rattle. It worked pretty good.
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
Box Blade (A62613)
Box Blade (A62613)
Pickup Truck Ladder Rack (A62613)
Pickup Truck...
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
2011 Ford F-150 Pickup Truck (A64194)
2011 Ford F-150...
