NEW 2610!
/ NEW 2610! #21
Hmm, Mine does not have this rubber insert either and its a 2008. I've lost 4 bolts that tensions the rops. They always tend to rattle loose and out. I need to get some more but this time I'll double up on the nuts to lock them in. I'll look into these rubber pieces.
/ NEW 2610! #22
Just drill a hole at the start of the threads of the bolt and insert a cotter pin or a set pin (after bolt is installed)... This way it can only loosen so far before the pin stops it from going any farther and falling out. Or a real easy way... After installing the bolt, just take a center punch and hit the last few threads, that should be all that is needed to stop the bolt from coming out "easily".
/ NEW 2610!
On my old 2310 I used rubber garden hose gaskets on the ROPS bolts to quiet the rattle. It worked pretty good.
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A65643)
2012 INTERNATIONAL...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
3 Bottom Plow (A62613)
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59914)
2025 PJ CC162 T/A...
2005 Mack Vision CNX613 (refurbished and retrofitted as novelty pick-up)  (A62613)
2005 Mack Vision...
