New 2601
/ New 2601 #1
burk1953
Wooster, Ohio
B2601
Upgraded from a B7510 to a B2601 w/ LA434 loader, RCK 69-32 MMM, B2765 Dozer Blade. I also replaced my old tiller with a RTR1258. So far the salesman was great, a little mix up for the quick attach for the blade.
Wishes. They would have given me a better tutorial on the new equipment. A lot of frustration taking off the mower and mounting the blade. I don't like the location of the hydraulic remotes, I can see many busted knuckles. IMG_0562.JPGIMG_0563.JPG
/ New 2601 #2
Wow! That is a beautiful machine! Don't sweat the mower installation, after 2 or 3 times you'll be able to do it in the dark! The Kubota engineers did a really good job!
/ New 2601
After 10 years with the B7510 I never liked removing or installing the mower anyway. I need to weld hooks on the bucket and add a work light to the back.
/ New 2601 #4
Congratulations on that great new tractor, burk!
Owning a B7500 I'm just curious what improvements/capabilities the B2601 offers over your B7510 other than the 3-speed hydro, 5 more hp, and position control, which by themselves are significant.
/ New 2601
I notice the power difference right away. The control for the loader valve seems to be a plus what little I've used the loader so far. The rocker foot pedal will take some getting used to over the heel and toe pedals. Hood and grill is all one piece, easier access to clean the radiator. New mount for loader, no bar to dent hood. Better placement of the left side controls. I always caught on the ones on the B7510 when getting off. Drive over mower deck, not sure, many have told me not to do it. I don't like the location of the front remotes.
More to come as I have more seat time.
/ New 2601 #6
Congrats. Did you get front and rear remotes? Would you mind posting pics of the remotes? I haven't seen one with factory remotes.
/ New 2601 #8
Thanks for the comparison more power is always a plus. I have caught the left side controls getting off as well and scuffed my hood with the crossbar so it's nice they addressed that. Where did they put the front remotes and where would you preferred they were?
/ New 2601
Behind the loader mount. They are out of the way but with my hands, hard to get to. They should be readily accessible, at least for my needs.
/ New 2601
They are between the loader mount and the hood. I will take a pic when I get back.
/ New 2601 #12
I just raise the front up with the loader and pull the mower out from the right side, very easy to do on a cement floor. I don't think you will hurt the deck driving over it though.
/ New 2601 #13
I suggest getting the small cup dollies and putting one under each anti-scalp wheel. The mower drags in/out from under the tractor with ease. As others have said, lift the front of the tractor with the loader... so much easier. My B2620 had a drive-over deck. Never used it. On my BX2670, I've tried it, and it is the cats meow. Remember, if you drive over, DON'T do it with the loader on. The weight will likely cause damage to the deck.
/ New 2601 #15
Very nice. I really like the snow blade. Do you have chains for it?
/ New 2601 #16
Good point, I found my industrial tires to be *very* slippery on snow and ice but I now just switch to turf tires for winter.
/ New 2601
I never used chains on th 7510. I plowed downhill on the drive and never had a problem on the flat.
/ New 2601 #18
Why wouldn't you take advantage of the drive over mower deck feature? That is one of the reasons I bought mine. I drive on and off it many times throughout the summer with my loader on and it doesn't hurt anything.
/ New 2601
Every one I talked to including the dealership was afraid it may cause premature cracking in the deck. Your the first person I've talked to that has used the drive over feature. Thanks for the input.
/ New 2601 #20
I'm seriously considering buying a B2650 with a 6' drive over deck.
Is premature deck cracking common on all brands of drive over decks, just unique to Kubotas, or just B2601/2301?
Anyone know who Kubota sources their decks from?
2017 DRAGON 150BBL ALUMINUM VACUUM TRAILER (A63569)
2017 DRAGON 150BBL...
70in Rock Bucket Skid Steer Attachment (A61572)
70in Rock Bucket...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
24in excavator tooth bucket (A61307)
24in excavator...
