New 2305 - dash lights and other observations
   / New 2305 - dash lights and other observations #1
bxowner
Vermont
John Deere 5055e
Took delivery of a new 2305 last night. Too bad it doesn't have a "4WD engaged" dash lamp like the 2320 had. Also, if I recall correctly, the 2320 had a glow plug lamp that would extinguish after about 3 seconds - the 2305 has an oil pressure lamp and a battery charge lamp that stay illumintaed until the engine starts. At least there's still the fuel solenoid "click" so I know when enough time has elapsed to start. I know, I know, "it's sooo hard to count to 3. And god forbid you have to look down at the lever to know when the tractor's in 4WD." But, the lamps were handy. And, the 4WD light on the 2320 was dead accurate - if it wasn't lit, even if the lever felt engaged, I knew the 2320 wasn't in MFWD.
There are a number of pros and cons - as everyone knows - between the two tractors. The pros I found immediately are: (1) quieter engine. It's the same motor on paper, but definitely quite a few decibels lower, especially at 3000rpms; (2) very little hydro transmission whine. I have a slight incline on my driveway and whether I was in "low" or "high" range, the 2320 made a racket - add a load to the bucket and it sounded like it was straining to get out of its way. Of course, it wasn't, but it sounded that way. Amazing how much more torque can go through the smaller tires; (3) turfs are a lot more comfortable than R4s; (4) I like the placement of the throttle lever better on the 2305, as it feels more natural to push it forward, rather than "up" (I always felt like I was putting the 2320 in "park" - like on an American pickup transmission lever); (5) I don't have to fold the ROPS to park it; and (6) the chains won't be such a bear to put on/off - the style I had on the 2320 were easily 60 lbs. each and, while they offered incredible traction, they were impossible to fit properly and didn't "seat" themselves until 50 yards of travel, which necessitated readjustment. Oh, and they took out my hydraulics once when they loosened ever-so-slightly, costing me $300 worth of repair, on top of the initial $425 for the chains.
Cons-wise, well, the 2320 gets the nod for styling (it not only looks cool, but looks like a real tractor), position control 3-pt and split brakes. I'll miss the first and third observation, as I don't use the 3-pt.
I also expect my wife will actually use the 2305 - probably ought to put that in the "con" column, though, as (selfishly) I won't get to use it much.
   / New 2305 - dash lights and other observations #2
Why did you replace the 2320?
   / New 2305 - dash lights and other observations #4
If you check your manual the pre heat option on the 2305 is only acitvated by having the key in the crank position. To properly use in cold weather put the range lever in high or low and hold the key in crank position for a few seconds then put range lever in neutral and start engine.. Im not impressed with this design but it works good and these engines start well in cold weather... The 2305 is a tough little tractor!
Upgraded from a BX1500 to a JD 2320 a couple of years ago to handle a chipper and maintain a private road in the winter.
Downsized property.
Downsized tractor.
Downsized payment.
Never bothered to change handle.
MS-Honda - thanks for that description. Read the manual last night - says it's a 3-second glow plug. Wonder if the design has changed. Will have to recheck.
   / New 2305 - dash lights and other observations #7
That's incorrect. The 2305 uses glow plugs - The glow plug heat always goes on for about 3 seconds when you first turn the key to 'ON' (Not crank). And it's easy to notice. The lights burn dim (From the juice for the plugs) until the solenoid kicks out then they get bright. That's when to start. If you want MORE than 3 seconds you can use the technique of putting it in gear, and turning to crank for as long as you want but I find that's not necessary.
I've started down to just about 0 degrees without needing any extra pre-heat than the 3 seconds. The 2305 has glow plugs, many of the other tractors (including my 3720) have air pre-heaters.
   / New 2305 - dash lights and other observations #9
We know LB...You may have mentioned that several hundred times before...:)
   / New 2305 - dash lights and other observations #10
You beat me to the punch. It make me wonder why he is always posting in the John Deere section.
2019 Kubota SVL 95-2 (A47477)
2019 Kubota SVL...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
Year: 2008 Make: Pierce Model: Enforcer Vehicle Type: Truck Mileage: Plate: Body Type: Crew Cab O... (A55852)
Year: 2008 Make...
Eagle Weathervane (A55758)
Eagle Weathervane...
Skid Hydraulic Hoses (A50775)
Skid Hydraulic...
