New 2025 B2601 vs used B2601
   / New 2025 B2601 vs used B2601 #11
Used one, it is not a briner, with 300H service and new wheels if you wish so, you are not getting to $14K expense.
BTW, it is a pinned loader
I thought the quick connect was the bobcat style like shown.
   / New 2025 B2601 vs used B2601 #13
It has SSQA ends on the loader which enables you to easily swap front loader attachments. The loader itself appears to be bolted on so it can't be (easily) removed. No big deal IMO.
   / New 2025 B2601 vs used B2601 #14
Appears not to have had the best care, but with some TLC and clean up it will be a nice machine. And agree it has the QA bucket.
   / New 2025 B2601 vs used B2601 #15
I would spend the money and buy the new one. If you take good care of it, you
will be happier with spanking new everything and knowing it will last a lifetime.
This is the used one and isn’t that QA? I am still learning the difference QA or SSQA.
   / New 2025 B2601 vs used B2601 #18
Yes - this is SSQA and that's a good looking Kubota - buy it! You can fix the deck wheel easily.
   / New 2025 B2601 vs used B2601 #19
The loader to tractor attachment has the same pin style as other Kubota loaders.
Easy off, maybe 5min to remove the loader assembly, no tools required.
   / New 2025 B2601 vs used B2601 #20
Yes, my bad, in the first picture i did not see the disconnect part, sorry
If i needed a tractor, i'd buy this in a heartbeat. 300 hours is nothing, change all the fluids, grease all the pins and you are GTG
Dad's Garage Metal Sign (A57454)
Dad's Garage Metal...
TANK MANIFOLD (A55745)
Pallet of Assorted Woodworking Power Tools (A57454)
Pallet of Assorted...
TOPCAT BDRC ARTICULATING BRUCH CUTTER (A58375)
TOPCAT BDRC...
(4) Tires (A57454)
(4) Tires (A57454)
8' Avalanche Snowbox (A55272)
8' Avalanche...
