New 2011 Cub Cadet Garden Tractor!!
   / New 2011 Cub Cadet Garden Tractor!! #61
They make these decks with the "One Size Fits All" design. You can bag, mulch or discharge with the same deck. I mostly discharge. Just blow and go!
I mainly use the bagger for leaf clean up in the fall. I am not really impressed with how it mounts to the deck. I wish it connected like John Deer baggers do. On Mine I have to stop every now and then to make sure the chute doesn't come off.
As far as the mulch plug is concerned, I have never used it and most likely never will.
Michael
   / New 2011 Cub Cadet Garden Tractor!! #62
Yeah, I didn't mind the plastic mulch plug with my 2544. My grass (or closely-cropped weeds) is never thick enough to be an issue and I LOVED that mulch plug for leaf-grinding in the fall. That's probably why my 2544 left such an awesome cut for me; because of my type of 'grass'.
In regards to these new fab'd decks for 2011, I'd assume they're like my 2010. No more mulch plug. You have to purchase a mulching kit which is a steel baffle set, bolts and hardware. The deck has to be removed, inverted and stuff removed/replaced. Once it's on. It's on! It's over $100 for the kit. I've been tempted, but I don't like the thought of having to pull the deck to do wrenching to go from mulching to blasting and back.
Joel
   / New 2011 Cub Cadet Garden Tractor!! #63
Joel, I think you are right on the 2011 fab decks being like yours. They look so similar. I guess we'll find out!
Do you get alot of grass clippings on the top of your Z force deck? I get alot on top of my 2518. It's more of a pain than anything. Good thing for air compressors!
Michael
   / New 2011 Cub Cadet Garden Tractor!! #64
Yep, the whole machine gets dirty with every mow. The fab'd 44 does seem to be easier to clean up, up top, but a little harder to clean up underneath than the stamped 44. It's more like an inverted roasting pan with more squared off edges and whatnot. I jack the front up after every use and scrape the underside.
Joel
   / New 2011 Cub Cadet Garden Tractor!! #66
I'd guess because it is cheaper than hydraulic ps and lift.
   / New 2011 Cub Cadet Garden Tractor!! #67
I was just on the Cub Cadet website. Looks like the new Series 2000 line will be added to the mix. The 2500 and 3000 series were still there.
   / New 2011 Cub Cadet Garden Tractor!! #68
Yes, I dunno why they still have the 2500's and 3000's listed on the site. As far as I know those units went out of production around June 2010 and are being replaced with the new 2K series.
Joel
   / New 2011 Cub Cadet Garden Tractor!! #69
Look at the cost between a 2542 and the 2000. If I remember correctly the cost is the same and you get a deck with the 2500 and a larger engine.
I know which way I'd go.
   / New 2011 Cub Cadet Garden Tractor!! #70
New to the forum but not new to Cub Cadet. The New GT2000 just arrived and looks to be a decent tractor. Cub Cadet been swapping more model numbers than i swap on price quotes it seems lately. The GTX2000 has been replaced with the GTX2100 well almost....that was just changed to a GT2100 and will offer an electric lift. The only garden tractor model that will offer the electric steering is the GTX2154LE.. The prices as of 3-14-2011 are as follows:
GT2000 MAP 3,599-3,999
GT2100 MAP 4,999-5,499
GTX2154LE MAP 6,999
4 year /300hr warranty
My first post , hope it was informative
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
210000 (A60429)
210000 (A60429)
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2018 Ford F-350 (A55973)
2018 Ford F-350...
