New 1610D owner questions
   / New 1610D owner questions #1
kenr74
Amity, OR
Yanmar 1610D
Hi all,
Just picked up a new to me 1610D and have a few questions. First tractor and first diesel so I don't want to screw it up. I have managed to figure out what everything does without killing myself so good start. Should have bought this a year ago when I moved. I hope to never use a shovel and wheelbarrow again!
I have already changed the engine oil and filter, dumped the transmission fluid (there was barely any) and cleaned the screen. Haven't found any issues yet.
First question is about the starting procedure. Is there one? I'm assuming it has glow plugs(do I need to warm them up before engaging the starter?) Mine seems to like about 1/4 throttle to start then more throttle for a minute to warm up.
Second question is about the engine stop lever under the steering wheel. Should I use it vs pushing the throttle all the way forward? When I push my throttle all the way forward the engine dies. Normal?
Finally, is there an advantage to using the foot throttle vs the hand throttle? I see that they are tied together but not sure I understand why they are both there.
   / New 1610D owner questions #2
Nice looking tractor! - Find a manual for it if you don't have one. I never use my foot throttle, Just there for an extra burst if you need it. The hand throttle does all of the work. Run the tractor with a bit more power (RPM) to get work done. You don't want the engine lugging down. A tractor beats hand work! - Nice tiller.
-air filter, hydraulic filter? - I don't know Yanmars other than they have a good reputation.
   / New 1610D owner questions #3
Sweet looking tractor! I just bought my first and it's a Yanmar too so we'll be on the journey together. I've used tractors for my day job for quite some time, though, and I've always thought that driving with the foot throttle is a bad habit you don't want to pick up. Don't ask me why. As tcreeley says it's there for quick bursts if the top of the hill is a little steeper than the bottom, etc.
Yours looks more well cared for than mine, but think about a radiator flush too. Shouldn't be too difficult and I've gotten good advice on my thread on the best practices.
Congrats!
   / New 1610D owner questions #4
Welcome to the forum. :welcome:
It doesn't have glow plugs. It has a thermostart element. Read here. Inside a Yanmar thermostart (glow plug) unit.
It would be normal to kill your engine by pushing the throttle all the way forward. I believe the lever under the steering wheel is the decompression lever. It should not be used to kill your engine. When you use the lever it holds your exhaust valve open just a tad so no compression is developed. This is to allow a fast spin for cranking, especially in cold weather. Your starting procedure is fine. Might want to try use the compression release on cold starts. Some hold the compression release long enough for the oil pressure light to go off, a tractor in good shape might go off in 2-4 seconds.
   / New 1610D owner questions #5
Now I use my foot throttle all the time. Esp with the FM.. Since I don't have power shift. And I finally a couple Yrs. back have my 2nd gear PTO working and staying locked into gear so I don't have a problem in waiting for the Mower to slow down so I'm able to shift even with using a overrun clutch. First gear PTO I run about 2000-2200 Eng. RPM's. so I just use the hand throttle. But almost impossible to stop and shift Quickly. But in 2nd. gear PTO I only run between 1500-1700 Eng. RPM's. and it enables me to stop and shift real quick with very little wait.;)
Thank you. Interesting stuff on the glow plug issue.
I think my tiller is a little big for the tractor but I'll try it again once we are actually in tilling weather. Tried it out once and all I was doing was chruning mud and bogging the poor thing.
I think this thing was probably fresh off the boat because the paint is way too nice and the oil filter was painted on.:shocked: Seems to function fine so fingers are crossed.
I didn't do the air filter yet. Forgot the number when I was at the store so it will be soon. I cleaned the hydraulic screen but it was very clean already. Not sure I have a filter too?
Forgot. This is the lever under the steering wheel. I believe you are correct about a decomp. It is connected to a linkage on the valve cover.
   / New 1610D owner questions #8
Yeah that is a lot of tiller. I'm 20 HP.@ the PTO and used a RS.1400 and it worked good except in fresh untilled soil and it was rough on it and slow going. But what I bought it for was a garden that was tilled with a walk behind. My soil is rock hard Ga. clay and if the soil was already tilled or broke it worked really good. This is the first turn of the year and the tiller is buried to the max. It won't go no lower and the pic. shows the results. With new tines of course and no Blk smoke. Yours looks in much better condition.
   / New 1610D owner questions #9
If you find it starts easier with more throttle give it more throttle. The manual says start at full throttle, then dial it back.
   / New 1610D owner questions #10
Changed my oil yesterday evening. It's that time to start getting everything ready for use for the next 7months of mowing in Ga.. I put a mark on my Hood which corresponds to 1500 RPMS. I just don't feel right having to open the throttle wide open. I believe it maybe some sort of typo? It's been sitting since Oct. and had to wait a count or two longer for the oil light to go out and BAM!!! hit like it was new. I believe mine was fresh off the Boat also. I actually cranked it up for Clemsonfor and he commented on how well it started cold. So if that is true it maybe a good thing.
2002 Scag STT61A-27KA Turf Tiger 61in Zero Turn Mower (A50322)
2002 Scag...
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
1989 Cat 953 Crawler Loader (RUNS) (A50774)
1989 Cat 953...
2018 Ford F-150 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
