New 1025r dont realy no when to change the oil for the first time.
   / New 1025r dont realy no when to change the oil for the first time. #1
bnoel10
Fournier ontario
1025r tlb lx176
Just got a new 1025r the salesman tells me change after 10 hours sounds a little soon the book tells me 200 hours sounds way to long ,
I wont to go synthetic when ,does anybody no.
Thanks
   / New 1025r dont realy no when to change the oil for the first time. #2
Split the difference and go for it at 20-30 hours. I did my Kioti at 40 hours, the book called for 50. I'm at 150 hours now and I'm switching to synthetic the book calls for 200.
   / New 1025r dont realy no when to change the oil for the first time. #3
Read the book carefully. Unless they have changed the first service is at 50 hours and then every 1 year or 200 hours after that. I am a big fan of synthetic oil but I use conventional oil in the tractor because the annual use of 50 to 100 hours doesn't justify synthetic.
   / New 1025r dont realy no when to change the oil for the first time. #4
Thanks
Read your manual, it will tell you when to change motor oil & HST oil. The earliest motor oil change I have heard of was on my Kawasaki 691V powered ZTR which required oil change at 8 hours but ONLY the oil, no filter change till 100 hours. MOST tractors require a 50 hour oil change for engine and with HST transmissions, hydraulic /HST oil along with all filters at that time but your OEM owners manual will specify the exact recommendations.
I wouldn't put too much stock in what a salesman says as many (most) of them barely know the color of the equipment they are selling.
Some manuals will even specify the time duration required before switching to full synthetic while others don't mention it. Personally I like to run the full 50 hours on the break-in oil to allow all the components to wear in as they should. Synthetic or regular oil is a personal choice as most of us don't put enough hours per year on a tractor to require synthetic since the recommended oil change is yearly or XXX hours. Cost difference for engine oil is minimal for most CUTs that may only hold 4-5 quarts so at most $10-15 difference.
Thanks for the post makes a lot of sense, when you changed at 40 hours did you go braking in oil again or regular oil ?
   / New 1025r dont realy no when to change the oil for the first time. #6
Read your manual as everyone has been telling you. All the things you want to know are in there.
   / New 1025r dont realy no when to change the oil for the first time. #7
Many say there is no such thing as breaking in oil. I have plenty of vehicles and my tractor where I just put in the correct spec oil at the first oil change and worried not. Granted my car only has 392,000 and does not use much oil (less than a quart) between 10,000 mile oil changes, the tractor does not need any oil added between changes, neither does my truck. Heck some car engines factory fill is oil like Mobil 1 full synthetic. Same oil you get at Pep Boys.
I have read mi book and unless I mist it only sais 200 hours.
maybe that is soon enough just sounds like a lot .
A car at 55 miles per hour for 200 hours would travel 11000 miles witch would be a lot for a first oil change in mi book.
   / New 1025r dont realy no when to change the oil for the first time. #9
I bet it say's 1 year or 200 hours. and what oil do they say to use?
   / New 1025r dont realy no when to change the oil for the first time. #10
I am sure my LS tractor had a non-detergent oil in it as breaking in oil. At 50 hours the oil was still clear as new oil. I put in Shell Rotella T6 and within a few hours the oil was coal black as diesel oil should be. Regardless of what is rumored, just change the oil as per scheduled maintenance in your owners manual.
I also don't believe that BNOEL10 properly read his manual when it said 200 hours before first oil change. Possibly 200 hours AFTER first oil change which most books say to do at 50 hours.
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55218)
2016 Ford F550 4x4...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
2018 FORD TRANSIT T150 CARGO VAN (A54313)
2018 FORD TRANSIT...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
