Never use an Abrasive Cut-Off Wheel Again?
   / Never use an Abrasive Cut-Off Wheel Again? #11
Well I'm a multi trade renovation sort of person and in a pinch as well as lazy I simply grabbed my angle grinder that had a diamond blade for cutting ceramic tiles and went at it to cut off a series of 3/8 bolts.
Naturally I had to cut thru the nuts as well.
I was very pleasantly surprised to see how well that blade performed as well as the durability.
One nice advantage is that the disc diameter does not change like with abrasive discs.
To note that the diamond disc that I was using was an 'el cheepo' and probably not using the best adhesive but it still did the job.
I later still used it on ceramic tiles and it still performed well.
   / Never use an Abrasive Cut-Off Wheel Again? #12
First time I've seen this for cutting metal. I've been using something similar for concrete for years. When I was at my plumbing supply house, they cut some steel pipe for me using a chop saw and a special metal cutting blade that looked very much like a fine tooth wood saw blade. It cut great. Fast and clean. I looked them up and felt they where too expensive for how often I cut metal with my chop saw compared to my regular cheap blades that I have.
   / Never use an Abrasive Cut-Off Wheel Again? #13
Actually, more and more guys are using the toothed blades for ferrous and non ferrous materials. Maybe bypassing this technology altogether. The first time I saw a friend cutting aluminum on his mitre saw with one of those, I said what the $%#& are you doing? Now they are using them for steel too!
   / Never use an Abrasive Cut-Off Wheel Again? #14
Problem with toothed blades is the RPM. They cannot be retrofitted to a cheap chop saw.
Seems these diamond blades are the ticket. concrete eats an abrasive very quick, diamonds last seemingly forever in comparison. If steel is gonna yield the same results, I think for the money, these are a good deal. Will wait to see how some you that have ordered like them.
I dont really buy into their claims though.
I DO believe they got 541 cuts through 25ga metal studs with their 14" and 391 cuts through the 1/2 rebar.
What I dont buy is the claims of how poorly the abrasive did. Only 6-29 cuts for 4.5" through rebar and only 6-13 through the studs for the chop saw....:confused2: Seems a bit far fetched IMO. When building my shop, I needed 60 4' pieces of 1/2" rebar for the cores, and had 12 20' sticks. Yep, 4-cuts each so thats 48 cuts. did it with a 4-1/2 (maybe a 5") zip disc. Maybe wore it down 1/2" in diameter overall. Could have easily got another 100+ cuts.
And the chop saw only making 6 cuts in light 25 gauge studs. How did they manage to wear the wheel down in only 6 cuts?
   / Never use an Abrasive Cut-Off Wheel Again? #15
I like diamonds.
   / Never use an Abrasive Cut-Off Wheel Again? #16
Chatter.
   / Never use an Abrasive Cut-Off Wheel Again? #17
Just ordered one. I'll post a review when I get it.
I'll wait for your review. My problem is I hate changing them out! and if this cuts that down it has got my vote.
Wonder if the labor saved in changing them out would make up the cost difference?
   / Never use an Abrasive Cut-Off Wheel Again? #18
Yikes...!...$200 for a 14"...supposedly on sale from $450.00...!
I just got a Makita cut off saw (2414NB) for Christmas...sure beats the "redneck plasma cutter" method (4.5" x 1/16" disks on a grinder)...!!...I'll wait and see how long the (original) abrasive blade lasts...
   / Never use an Abrasive Cut-Off Wheel Again? #19
You can by a 10" tile or rock blade usually for about $100. I've haven't used that size much on metal, but they will work I'm sure. We did a rock job years ago, homeowner picked out rock, we stacked rock. Homeowner wanted tighter joints (dry stack), but same rock. So 2 cheap miter saws with 10" diamond blades, a week later we turned 2 pallets of rock into bricks lol. We had about a pallet worth of waste when done! Thats what they wanted though. As I said above, love diamond blades! To me they are worth the extra price, but I don't use them on metal on a regular basis. My only concern would be getting it to hot, which will ruin it. I've done it on rock before.
   / Never use an Abrasive Cut-Off Wheel Again? #20
The pros use the diamond blades in the 4 1/2 inch angle grinders to cut vinyl siding. Amazing to watch a guy that has experience and knows what he's doing.
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
1275 (A50490)
1275 (A50490)
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
