Apr 26, 2023 / Neutral Safety Lock #1 D DennisK47 New member Joined Dec 7, 2022 Messages 7 Tractor MF 2705e My MF 2705e used to start in any gear as long as the brake was engaged. Now it will only start in neutral. What happened?
Apr 27, 2023 / Neutral Safety Lock #2 WranglerX Super Member Joined Apr 6, 2018 Messages 5,614 Location A Little Bit West Of Yosemite NP Tractor MF GC1715 One or more safety switches has stuck in non operated or operated position..... Suggest you first look at or work with safety switch on brakes to see if it is operating correctly.... It may be jammed or just plain failed....
Apr 29, 2023 / Neutral Safety Lock #3 GeneV Elite Member Joined Aug 19, 2019 Messages 3,202 Location Lake County, IL Tractor Bradley 48" stander MF GC1710 DennisK47 said: My MF 2705e used to start in any gear as long as the brake was engaged. Now it will only start in neutral. What happened? Click to expand... Can you take a pic of the safety switch? Wondering if it's similar to the one on the GC...I may have a solution for you.
