neutral power reverser problem
/ neutral power reverser problem #1
stumpeater55
ar.
4520 jd 2005
have a 2005 4520 jd .having problems with the power reverser lever . has to be In neutral to start but have to jiggle lever to make connection to start. was wondering is there a switch or connection from the ignition switch to the power reverser lever , one person told me there was an adjustment to a connector or switch and a mechanic said the only safety switch was located u nder the seat connected to the lever. another jd owner with a 4320 said he had the very same problem. any thoughts from you guys or mechanics where to look ? thanks
/ neutral power reverser problem #2
I disagree with the mechanic...
There is an operator's presence switch (dead man switch) under the seat...but there is also a neutral safety switch that prevents the tractor from starting in gear (which includes the reverser lever). Even my 14 year old Deere 4400 with sync-reverser has these switches.
However, I don't think it's a switch. I think you'll find linkage might be a bit loosened up over the years.
thank you for your input, that makes a lot of sense. I will look at the linkage.
/ neutral power reverser problem #4
I will guess that there's a switch on this power reverser control housing. I agree the shift linkage needs looking at for slack.
2018 JOHN DEERE 320G SKID STEER (A65056)
2018 JOHN DEERE...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
IRanch High-End Tricycle (A64119)
IRanch High-End...
2016 John Deere 250G LC Hydraulic Excavator (A66734)
2016 John Deere...
2003 FORD F-750 SUPER DUTY(INOPERABLE) (A67714)
2003 FORD F-750...
