Negative wheel camber
/ Negative wheel camber #1
56ford600
Thunder Bay, ON
Ford 630
Hello everyone,
I am brand new here, so I am sorry if this has been asked a million times. I just purchased a 56 Ford 600 with a loader. The previous owner replaced the front axle (axle only). The tractor has a large negative wheel camber ( out at the bottom - in at the top) on both front tires. I tried adjusting the axle to be wider, didn't help. When I had the tractor jacked up, I checked to see if the tires have any wiggle, they do, but very very little, the roll fine and turn fine. My only thoughts are the spindles are bent. I have no idea how to check. Any help would be greatly appreciated.
I am concerned they will just snap under load.
I am sure I will be a frequent poster as I try to fix it up, runs good, but LOTS of leaks, some 3 point hitch issues etc. But that is the joy of owning a 60 year old tractor.
Thanks.
/ Negative wheel camber #2
Axle upside down (or make it so) ?
/ Negative wheel camber #3
I couldn't find the kingpin inclination but I did find this picture that might get you in the ballpark to see if you have bent spindles or bent axle or perhaps both.
This site might be of some use to you (if you don't have it already).
Smith's Old Ford Tractors
Thanks, I hope to investigate further on the weekend.
/ Negative wheel camber #6
My Ford 4000's spindles were bent between the bushing lands on the vertical part. Made the tires rub on the knees.
Is the axle supposed to rise up from centre as it continues towards the tires? The outer edge of the axle is noticably higher than the centre.
/ Negative wheel camber #9
My guess is it is from too much weight load on the front from the FEL. I bought an IH 574 once and one wheel was like that. I figured it was like that for a while and was alright. Scared the s#!* out of me one day when it snapped off while lifting some dirt.
Well I have looked closely at the axle, I think it may have been installed upside down. The hump in the centre of the axle created by the bushing is toward the top on mine, axle slopes slightly downward from centre. Most of the pics I look at online have the hump created by the bushing toward the bottom. If I flip the axle, the axle would then slope slightly upward, which, would in turn change the angle of the knees, and the camber of the wheels,,,,,,I HOPE,,,,hahaha. Now I need to figure out how to turn the axle around.
Does any of that make sense?
Thanks for the help,
What a freakin day, well,,,spindles look fine, so I started to pull the front axle to flip it,,well,, boy did I have fun with that pin, after hours of banging and smashing, I got it out. Looked at the axle hole and it is ever so slightly oval, that's why it was so tough. So, I flip the axle and slide it in, nope, doesn't fit, the top edge of the axle hits the fan housing, pushing it up into the fan. The axle is stamped with,,,,NAA 3010 B2. I found online that the axle 9NN 3010 EA is the axle for the Ford 600 series, it says that replaces the NAA 3010 B2. But it also says that is for non-adjustable axle only,,,,,I believe I have an adjustable axle. i have spent 2 hours looking online and cannot find the appropriate axle.
Please help
/ Negative wheel camber #12
wow what a great Ford site. Thank you. It is so worth skulking around to find gems like this even on threads i have no idea how to help.
2012 FORD F-550 CAB AND CHASSIS(INOPERABLE) (A65643)
2012 FORD F-550...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
1966 Hale Livestock Trailer (A66285)
1966 Hale...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
