Needle Valves
/ Needle Valves #1
MrChris
Georgia
Mahindra 3215HST
Thinking of adding needle valve/s to get finer control of my hydraulic top link cylinder. I have one set of remotes (2 hoses with 2 QD). Do I need to add a valve on each hose or just one since I understand a needle valve restricts flow in both directions? Thanks.
/ Needle Valves #2
The purpose of a needle valve is to restrict flow . Same amount of flow in both directions.
The purpose of a flow control valve is to restrict in one direction, and free flow in the otherdirection
This needle valve has flow in both directions.
Surplus Center - 3/8 NPT 8 GPM PRINCE WNV-600 NEEDLE VALVE
This flow control valve has restricted flow in one direction and full flow in the other direction.
http://www.surpluscenter.com/item.asp?item=9-10440&catname=hydraulic
Meter in or out.
http://www.edgeroamer.com/sweethaven/mechanics/hydraulics01/default.asp?iNum=0504
Only one valve required.
2017 Case CX145D (A62177)
2017 Case CX145D...
2022 EZ-GO ELITE...
2359 (A64281)
2359 (A64281)
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
