needle scaler
/ needle scaler #11
Ive restored 2 many rusty things to list. best thing Ive found is wire wheels for angle grinder or die grinder I have a huge assortment. Watch out for flying wires tough.:mad: :drink:
/ needle scaler #12
Start out with the needle scaler to quickly get rid of the big flakes, other gunk and find the holes. Then switch to a wire brush and finally finish of with the sandblaster. Access may also determine which method to use.
The needle scaler is the easiest to use.
/ needle scaler #13
I just painted a tractor that ran a salt spreader most of its life so a fair bit of rust. As others have said the needle scaler is tough to beat for heavy flaking rust. Especially inside corners that are difficult to get access. I had started with a sand blaster ($50 one that you drop the hose into a bucket of blast media) and even wearing a full suit I had grit everywhere. The scaler was much faster but leaves a much rougher finish than blasting. For the cast pieces I didn't really care, it looked fine after ospho, primer, and paint.
For pieces small enough to fit in my HF blast cabinet, they came out great.
Edit: I have the small HF scaler. It works surprisingly well for how cheap it was. I did have to bend the trigger a couple times so it would depress the air inlet valve all the way... otherwise it slowly lost power.
/ needle scaler #14
. . . And an oscillating wire brush is the one that will clean down into the pits. Spinning just skips over the top. Use of Ospho afterward is a big step to eliminating the sand blaster.
/ needle scaler #15
I have an air hammer with a needle scaler nose attachment... Great combo... the air hammer is priceless... Drive out lug bolts... relieve stress in metal... Cut metal with a chisel tool... It's a small jack hammer too.....
/ needle scaler #16
What make/model oscillating wire brush?
Aaron Z
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2012 Ford F-350...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61307)
PENDING SELLER...
2016 Texas Trailers 26ft 5 Ton T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 Texas...
2018 BOBCAT E45 EXCAVATOR (A59823)
2018 BOBCAT E45...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
