need yoke for New Holland 479
   / need yoke for New Holland 479 #1
cowridermi
Addison, NY
MF 65, MF 1080, MF 1100, Kubuta B8200, Farmall 504, Farmall Cubs, Farmall Super A, Belarus 250AS's, Belarus 611, JD F935
I have a New Holland 479 that had the yoke broke on the slip clutch [86500915]. It uses the 47621 u-jount, crosses to Weasler 200-1875, 1-1875 Neapco. I would like to cut the broken yoke off and weld in a new one but have problems finding one to weld on. Does anyone know of a yoke that I can use?
   / need yoke for New Holland 479 #2
Any auto parts store should have a pair of joints you can make use of. Have you tried TSC, Rural King, etc. to find a pair ? as long as you can attach one side, you might as well do the partner.
I have the u-joint but the problem is that the yoke broke off one side, I need to replace the yoke. TSC has pto yokes but not for this size, nor is it listed in the Weasler catalog.
Bearing Diameter A. 1.00"
Overall Length B. 3-1/8"
Lock Up Dimension C. 2-11/32"
Inside Lock Up
   / need yoke for New Holland 479 #4
Thanks, I order one and will give it a try.
SET OF 51" HANG ON WHEEL LOADER FORKS (A51246)
SET OF 51" HANG ON...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
