need wiring schematic for my IH 284 diesel ignition switch
   / need wiring schematic for my IH 284 diesel ignition switch #1
Gitche Gumee Kid
NW WI
IH 284
Bought new ig switch. Thought I copied the wire color scheme but ended up with a solid red wire and ran out of terminals. This is a IH 284 diesel .
Any help for an 84yo that used to be a pretty good handyman wba.
GGK
Inter net search dosen't ,so far, reveal what I need---->color scheme for the six terminals on ig sw.
GGK
   / need wiring schematic for my IH 284 diesel ignition switch #4
I looked through many of the wiring links that Alan W provided.
At most I see ignition switches with 5 terminals. Does yours have 6 terminals or is it that you have 6 wires and 5 terminals?
Many switches have more than one wire per terminal.
Can you follow your red wire to see where it originates from. I suspect it is either power to the ignition switch or a connection back to the charging system
How are the terminals on the back of your new switch marked or labelled?
Dave M7040
   / need wiring schematic for my IH 284 diesel ignition switch #5
I did find this pic. Once again hope it helps.
Dave M7040
The new switch can be greatly viewed from ---->https://www.amazon.com/gp/product/B07Z7HZ8YM/ref=ppx_yo_dt_b_asin_image_o00_s00?ie=UTF8&psc=1
   / need wiring schematic for my IH 284 diesel ignition switch #7
Did the old switch have more terminals than the new? If not then how was it ever connected.
At this point you are going to have to get a meter and or test lamp and start tracing the wires and see what they go to.
Then you can hook them up correctly.
I apprciate the input.
GGK
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
2011 Ford Mustang Coupe (A55758)
2011 Ford Mustang...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54757)
KNOW BEFORE YOU...
