Buying Advice Need/want a new tractor
   / Need/want a new tractor #11
With that much property you want to do the new tractor thing right the first time. My brother has 250 acres that he hays and works in one way or another, he has a 75hp JD 4x4 with a loader for some things and he has a 110hp 2wd tractor for the heavy haying equipment. It's tough to have one tractor that does it all but if I had to have only one it would have 85-100hp, that would pretty much cover your bases.
   / Need/want a new tractor #12
as said the buddy seat is great.my tractor doesnt have the buddy seatnor does it have sirusxm radio wich id love to have.you also have to remember a cab tractor eats hp.by that i mean it takes 10hp to run everything in the cab.
To save a lot of time, will you tell us what an honest budget is? This can make a HUGE difference with what recommendations are-should be made.
I say this because years ago a guy asks similar questions, but says he has a 20K budget. Then out of the blue he spends 100K plus on just the tractor. :shocked: By doing that, everything was just wasted time for everyone. Might have been no big deal for that OP, but for everyone that was actually trying to help the guy, it was just a slap in the face.
It goes the other way also, people make recommendations in the 40-60K range and it ends up that you can only spend 30K.
List out some parameters and it helps you and everyone trying to help you. ;)
Tenative budget is $50k. That makes me really nervous. I can afford it, but I don't want to spend that kind of cash and then have a machine that won't do what I need, or that is costing me in repairs. I bought my 245 for just $5k with implements (except the bushhog - that I bought later) I had to put $4k into repairs (was expecting 2, but more was wrong than expected) It runs great now, but I keep breaking things. I tore off the right break pedal somewhere, and can't find it, or a replacement. I've broken the L brackets to the steps (they're 45 years old, I think it's just stress fatigue) but it's a pain to find replacements. I don't want to be having to hassle with that anymore, which is why I'm thinking about a new machine.
I could probably stretch to 60k, but would really like to keep it under $50k. Wife seems good with that, so its a pretty solid number.
Are you planning on keeping the MF for "smaller" work? Like near the house or yard area? I'd think about 2 tractors, a small one for light duty chores, and a larger one (50-75 hp) for the pasture work.
I've been debating that. We don't really have much to do around the house - can do it with the push mower easy. Someday might get a zero-turn when the mower dies. There are two 1/2 acre pastures on either side of the house that the smaller tracter might be better for. And a smaller tractor might be better for keeping the fire breaks up because it isn't very wide. On the other hand, maybe I should just make it wider, since I haven't been doing the upkeep on it I should due to no cab on the smaller tractor and repars...
Telescoping lower links and stabilizers makes changing implements easier. A quick hitch makes it even easier but not all implements fit.
You will want implements sized to match the new tractor so don't forget to include them in the budget.
You only need to be near a dealer if you're using the dealer a lot. If you do your own maintenance and don't have warranty issues or major repairs that are beyond your knowledge or tools, you don't need to go to the dealer at all.
Lol. I wish I could, but I think I'm slowly learning my limits. I'm definitely not a mechanic. My handle is ArmyDoc because that's what I am, I just work at the VA now instead of in the Army. I had hopes my son would be interested in the farm, since he works at a large truck service center, but his interests are more towards the welding end, and he's not much interest in the farm. Thankfully, he will do metal work for me if I bust something too bad... just takes a bit of time to fit it into his schedule.
   / Need/want a new tractor #17
Like another poster above, we have a Kubota MX5800 and really like it. We have also had a MF 245, a Kubota 54 hp and a Kubota L3800. Aside from the size issue you are addressing, my only feedback is that if I were you I would get 4WD, an HST transmission, and a FEL with hydraulics so you can operate a grapple and/or a 4-in-1 bucket. To me, those features greatly increase flexibility, utility and ease of operation.
Thanks for the input everyone. It sounds like the consensus is that something around 75hp will be enough for my needs. Any more thoughts on brand? I stopped by the Case dealership yesterday (nothings open, but they are closest and I figured I could look at what was on the lot.) They have a 75C with loader for about $47k. Good grief these things are beasts compaired to my little MF245.
So far JD and Kubota have been recommended. Can you tell me why? I have a friend who started with Kubota, loved it at first but recently switched to JD. He says it's better, but I remember how he raved about the Kubota when he first got it, and I can't help but thing recent purchases are always the best thing out there.
Thanks for the specific recommendations regarding options - hadn't much thought about that aspect yet. Do you think I should get the 4 in 1 bucket right off then? Or do you switch between the two?
   / Need/want a new tractor #20
In the HP range your looking at my vote would go to JD, JMO..
2017 John Deere 5090GN (A53317)
2017 John Deere...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
