Buying Advice need to upgrade
   / need to upgrade #21
I just think the front might be a little light...
It was, good call. That's why I made a bracket to double up on the weights. :thumbsup: Still handles like a sports car with the loader off though. :cool:
   / need to upgrade #22
When I was looking for a cab tractor, I found that most manufacturers cab models start around the 35-37 HP size. Mahindra does have a cab version of the eMax25, but it's not heated or air conditioned, and not the increased power you want. Based on most posts here on the subject, I doubt you'd be disappointed with a slight step up in HP. We went with the LS. But, Kubota, MF, and NH all have nice cab models as well. There also seems to be a lot of love for Kioti here (I've not experienced one yet). They all have a little different feel and layout. Try as many as you can to find the one right for you.
   / need to upgrade #23
You doubled the weight from what is in the picture?! I'd love to see what that looks like.
I know what you mean about taking the loader off and feeling like the tractor is suddenly articulated.
   / need to upgrade #24
No, the picture is with the weights doubled up from what the factory offers. I also added a couple of rear wheel weights. :rolleyes:
But back to the OP. Again, to get the size that I felt you were asking about, I'm pretty sure that Kubota is it as far as an all factory setup. Step up another frame size and you have quite a few different options. ;)
   / need to upgrade #25
Cool. Thanks for the pictures. Surely it's not light in the front now! :drink: (sorry for the tangent)
   / need to upgrade #26
Branson 4520c?
   / need to upgrade
Thanks for that....i am finding the same thing.... JD does not use a factory cab till the 3033 model...alot of $$$$ i dont want an aftermarket cab..
   / need to upgrade
i will check this model out...thanks alot
   / need to upgrade #29
TYM has a cab for the T234. That has a 24 hp Mitsubishi in it. Loader max at pins is over 1300lbs.
   / need to upgrade
ok, i will check this out...thanks alot
Cushman Electric Cart (A55853)
Cushman Electric...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2023 TRANSCRAFT 53FT FLATBED TRAILER (A57880)
2023 TRANSCRAFT...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
