Need to stand up a deer blind
   / Need to stand up a deer blind #1
JeepHead
The hills of Southern Indiana
Kubota 2502H, HSI Pinnacle grapple, LP 48" forks, LP 60" BB, KK tiller 60", KK middle buster, Pat's QH
So I am building a deer blind that will be sitting on 12' posts. I am building the blind at the house and will carry into the back property, attach the posts and stand it up using my L2502. Looking for suggestions on the safest way of doing this. Can't get a truck in the area, only my tractor and ATV. I think the max lift height on my loader is 8' to the pins so with the forks tilted up, I should be able to reach 12' to push it up. I was thinking of tying a rope to it so that as it's pushed up, it can't fall backwards from the momentum. Any thoughts?
   / Need to stand up a deer blind #2
You have a winch on atv? I pull up my stand with atv winch with rope tided back other side so it doesn't continue over , You can also use tractor to pull up ,over till tipping point , then use atv winch to then let down slowly from other side { remote winches make it a one man job}
My Rubicon doesn't have a winch on it but sounds like it needs one!
   / Need to stand up a deer blind #4
Could you rig something like this for your FEL bucket?
You could also clamp a 4X4 to your fork tines to get some added height.
   / Need to stand up a deer blind #6
Or pull it up using a pivot pole
   / Need to stand up a deer blind #7
Your pivot pole could be cut at blind location, out of a small tree. Would cut down on materials carried!
With a couple of snatch blocks, you could use the tractor for pulling it up and control at the same time. It just requires some longer rope. You would pull through the rear block while the front rope goes through other block for control.
Just plan it all out before installing to try not to forget everything you'll need. Put it on paper and check it off! Made that mistake before.
   / Need to stand up a deer blind #8
If you have the legs properly braced, then get it off the trailer, laying flat, it should be able to be pulled upright with a rope/strap without issue. Just kinda block the bottom of the "lower" legs and pull it into standing position. If that's a bit unlevel/plumb, you can always lift by wrapping a rope/strap on the legs once standing and lift one side, shovel to level, and lower until happy. If it's not stable enough to stand from laying to standing, and X bracers from about 18" up to the top, using 2x4x14 PT (or 2x4x16)
   / Need to stand up a deer blind #9
I've used the Pivot post method to raise a couple of Tower stands
  1. Make sure legs are cross based
  2. Slightly elevate the top of stand (I use a concrete block)
  3. Stake in front of the legs on the ground so they don't slide
  4. Connect rope/cable/chain/strap to platform
  5. Set pivot post (I dig it in a few inches) - Loop rope/cable/chain/strap over pivot post
  6. Slowly pull it up while helpers (or ATV) pull on ropes on the back side to slow the tipping once over center
  7. At some point the pivot post will fall aside, but the rope is taught enough at that point
  8. Level the blind
Hey I really like this idea! Thanks for sharing it
2004 Ferrara Apparatus Pumper Fire Truck (A55852)
2004 Ferrara...
Club Car Electric Golf Cart. (A55758)
Club Car Electric...
JMR 40" Mini Root Grapple (A53316)
JMR 40" Mini Root...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2012 Honda Civic Sedan (A55758)
2012 Honda Civic...
