Need to rebuild your engine coupler?
   / Need to rebuild your engine coupler? #1
Fitch4123
Terramite T5C
Just got done rebuilding the engine coupler, found all the parts required. listing the part numbers from Neapco but may be crossed reference, they are 1000 series PTO yokes. I measured and found the dimensions at https://www.neapcoaftermarket.com/wp-content/uploads/2019/11/2001ptocatalog637.pdf
Engine/transmission coupler U-joint/ Neapco 1-1071
Center yoke Neapco 10-5303 (1-11/16") / 10-5361 (2.50")/ Dana 10-26-47 ( 2.125")
End Yoke/ Neapco 10-0463 (7/8" hole 1/4" key/ 2.50 L)
Neapco 10-0493 (1" hole 1/4" key / 2.50 L)
Neapco 10-1703 (7/8" hole 1/4" key/ 1-11/16"L)
Neapco 10-1705 (1" hole 1/4" key/ 1-11/16
Danfoss pump shaft seal is NOK 16253-16 replaced it with McMaster-Carr #1199N66 (McMaster-Carr
   / Need to rebuild your engine coupler? #2
Saved, Thanks!
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2024 Yakta YXR710 Zero Turn Lawnmower (A57453)
2024 Yakta YXR710...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2013 John Deere 824K Wheel Loader (A56438)
2013 John Deere...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
