Need to know how much to torque to...
   / Need to know how much to torque to... #1
ArkCivEngr
Russellville, Arkansas
Kubota L3400DT, John Deere X495
I recently damaged the back-plate on the transmission on my X495. I have the new plate, gasket, fluid and filter. But I don't know what to torque the bolts to. My local JD shop foreman and I spent several minutes looking over his books, but he didn't have a tech manual for any of the X-series. He looked up a similar plate on the older 455, and it showed to be 20 ft-lb.
I'd rather be certain before I do this. If anyone has access to this info, I'd sure appreciate it. The part number is M810219.
   / Need to know how much to torque to... #2
Those are M8 threads. Note that you have two different lengths going through that plate.
Per my web search, an M8 thread should be torqued between 16 ft-lb and 20 ft-lb (depending upon the class of thread, which isn't called out on the Deere parts web site).
So, I suggest you use anti-seize and torque those bolts to 20 ft-lbs.
   / Need to know how much to torque to... #3
Your right Roy,
Just checked with a friend that has a x- series Technical manual CD, 20 lbs is right.
Thanks guys. /forums/images/graemlins/smile.gif
Now all I need is a decent torque wrench. /forums/images/graemlins/grin.gif
2022 Ford F-450 Super Duty STX Pickup Truck, VIN: 1FT8W4DT2NEC20764, Crew Cab, 4x4, Fx4 Off Road, (A59076)
2022 Ford F-450...
2015 FORD F-250 SUPER DUTY (A58214)
2015 FORD F-250...
2020 Am-Tank 800 Gallon Fuel Tank, S/N 73348, Nominal Capacity 838 Gallon/3172 Liter w/Spill (A59076)
2020 Am-Tank 800...
Water Line Hose (A59076)
Water Line Hose...
1710 (A58375)
1710 (A58375)
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
