Need to know how much to torque to...
   / Need to know how much to torque to... #1
ArkCivEngr
Russellville, Arkansas
Kubota L3400DT, John Deere X495
I recently damaged the back-plate on the transmission on my X495. I have the new plate, gasket, fluid and filter. But I don't know what to torque the bolts to. My local JD shop foreman and I spent several minutes looking over his books, but he didn't have a tech manual for any of the X-series. He looked up a similar plate on the older 455, and it showed to be 20 ft-lb.
I'd rather be certain before I do this. If anyone has access to this info, I'd sure appreciate it. The part number is M810219.
   / Need to know how much to torque to... #2
Those are M8 threads. Note that you have two different lengths going through that plate.
Per my web search, an M8 thread should be torqued between 16 ft-lb and 20 ft-lb (depending upon the class of thread, which isn't called out on the Deere parts web site).
So, I suggest you use anti-seize and torque those bolts to 20 ft-lbs.
   / Need to know how much to torque to... #3
Your right Roy,
Just checked with a friend that has a x- series Technical manual CD, 20 lbs is right.
Thanks guys. /forums/images/graemlins/smile.gif
Now all I need is a decent torque wrench. /forums/images/graemlins/grin.gif
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
2015 FORD F-450 SERVICE TRUCK (A52472)
2015 FORD F-450...
