Need to drill a hole...
   / Need to drill a hole... #11
So then I just need a bi-metal hole saw with an arbor and bit and I'm good, right?
And some cutting lube.
But if your drill press don't turn slow enough, game will be over in short time.
   / Need to drill a hole... #12
I've done bunches of holes in the last week in 1/2" plate. Holes from 3/4" to
1 1/2". I use the standard bi metal hole saw and a drill press going slow with lube. It works just fine with tolerances close enough for tractor work. The carbide tipped hole saws are even better, and much faster, but they cost about $30 to $40 each so I find the bi metal a better alternative.
   / Need to drill a hole... #13
Guys, I need to drill a 1 1/8" hole in 4 pieces of 3/8" thick mild steel. I don't have a plasma cutter or a torch...all I have is a good drill press.
What would you use to do this job with given my lack of equipment? I've looked around here and there are no bits that large for sale anywhere that I've seen, but would a step drill do it? I have drilled up to 3/4" holes around here but I've never had to do one this size and I was wondering what would be best to use in my situation.
Thanks!
Try Langford Tool in Minneapolis,MN they have 1 inch and i-1/4"
Your tal;king about $65 for the big one. They can order a1-1/8"
Give Ben a call. I've used these folks numerous times and they are an old time Family shop that is great to work with.
Good luck!
John
Langford Tool & Drill Co. / Mason-Cutters
1125 Washington Avenue South
Minneapolis, Minnesota 55415
612-332-8571 * 800-342-6228 * Fax 612-332-9137
   / Need to drill a hole... #14
I once thought hole saws were only for wood. I could not believe how well a good one can cut steel.
Thanks everybody for the tips, this is just what I needed to know!
   / Need to drill a hole... #18
Hougen Mag drill with a rota broach (angular) cutter
would be nice but I doubt you have one of those around.
hole saw I tihnk is your best bet since you have a limited number of holes. Might get by with one bit, but wouldn't hurt to have a backup with you. You could always return it if you didn't need the second bit.
   / Need to drill a hole... #19
hole saw I think is your best bet since you have a limited number of holes. Might get by with one bit, but wouldn't hurt to have a backup with you. You could always return it if you didn't need the second bit.
Yeah that -really- would be nice! But you're right, I don't have one. For as few projects as I have, it probably wouldn't pay for itself in my hands, but that is a super piece of equipment.
My drill press only goes down to 250 rpm set up from the factory. But, the triple pulley on the motor can be flipped over. I should have taken a picture, but long story short after I do that it will make the motor to drive pulleys both the largest size (instead of small motor pulley to large drive pulley) which should slow it down quite a bit.
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
2015 CATERPILLAR D7E LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
2017 KUBOTA SVL95-2S SKID STEER (A52707)
2017 KUBOTA...
2006 Ingersoll Rand P185 Towable Air Compressor (A55851)
2006 Ingersoll...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
