Need to dig a small diameter well...
   / Need to dig a small diameter well... #1
DaveInColorado
Fort Collins, CO
Kubota BX1500
I live in the smack dab middle of this medium-sized city, and we even have regular irrigation water through normal mostly unlined ditches. As a consequence of the unlined ditches, I get a 30' x 20' area of the yard that is soft from underground water coming out of the slope at that location. I won't go into all the details, but the short story is that I'm pretty sure that I can legally get away with putting in a 10-20' deep well into the underground layer of gravel. The goal is to eventually have 24-hours per day water availability for my backyard landscape projects as well as make that part of the yard more useful.
Can I use a regular category 1 posthole digger on my little tractor (Kubota BX1500 - should pull 400 lbs out at the end of the pivot) with extensions to get down that deep? I have a welder and can build almost anything - but am new to tractors in general. I will gladly risk a $100 auger being stuck in the ground in exchange for the possibility of having a good source of free water.
I tried driving a well point down but went too far past the gravel and now it is stuck in clay and someday I'll get it out, but not today. I hope to put in a 4" perforated pipe then drop a regular 1.5" PVC line down the hole direct to a pump. I could also be convince to put in a regular well pump.
Long story - I put in two 6' deep trenches a couple of years ago, filled with gravel, and redirected some of the water into my pond. I hit a 2' deep section of gravel on top of clay and concluded that was why the water came out where it did. I suspect that most of the water is being missed and I should have a good availability for standard garden use. I don't expect or need 50gpm. 5gpm would be OK.
I would rather not hire someone - just in case I have to cover my tracks.
   / Need to dig a small diameter well... #2
I really don't know, But it sounds like you have thought this out very well. If it were me I would try it. the only problem that I see is that every 5ft of auger you would have to pull it up to get the dirt out. 4" pipe will have less than 1 gal. of water per foot. What means have you tryed to get the point back up to the level that you want? If you put some timber cribbing around the point and something on the top of the pipe to jack against, then get a couple if 20 ton bottle jacks you might be able to raise it.
   / Need to dig a small diameter well... #3
Chances are you could use a manual post hole auger with 3 or 4 foot extensions to get to the depth you want. This would probably be much faster and cheaper than trying to use the pto auger.
My Grandfather and Father used to use a cable tool rig for water wells. They always started out by going down about 10 feet with a post hole auger and then putting in a piece of steel casing as a starting quide.
Egon
   / Need to dig a small diameter well... #4
Dave I drilled to a spring like that but I used a small forklift mast on the back of a 4000 Ford tractor at work. I knew where the spring was and wanted a spring to irrigate the turkey plot. I just made a 3point mount to go onto the tractor and were the forks went made a mount to hold an old 4 speed gearbox with a hydraulic motor on the end of it and an adapter to hold some 1 1/4 inch pipe sections. I used the tractors hydraulics to lift the mast and used a pto pump to run the auger for speed. My auger was a reinforced hopper auger out of a cotton picker. with a heavy point I made.
Id screw a 10 foot section of pipe to the raised mast and then started the whole rig you can dump first section of with the tractor because it will lift all the way out. When the first section is done you lower the auger in the hole unscrew it then ad another section of pipe. I hade water from the first 4 feet down. If I drill another on Ill use 2 lengths of auger so I wont have as much work to do dumping it. The whole operation took 11 hours to dig the hole. Alot of it was adding things to it with my portable welder to make it more user friendly like adding chain hooks to the mast sides to hold the loose augers when I would detach sections. I was drilling in a similar ground condition like you. I sold my rig to a local green house owner that wanted to make a few spring wells. I salvaged everything on that machine from other dead machines so I had about 25 hours time invested in the drill.
   / Need to dig a small diameter well... #5
I recall many years ago a farmer telling me the followng story. He said that he had a lot of cattle no money, & no water. So he went to the local hardware store and bought a 6" hand auger and 3, 21 ft. lenghts of pipe. What size I donnot recall. He then set up operations near the gable end of an old tool shed. Said that he managed to get down to 60ft.before he ran out of time. he said that he took the handle off the auger and had it threaded to match his pipe. when he had to add more pipe he would use the end of the shed to balance the 21ft piece of pipe. said that he never did get to water but the next year the bank gave him a loan to have a well drilled so he had the driller set up where he had started. the driller was amazed that the first 60ft of caseing slide right in with no problem at all. The farmer then told him what he had tryed to do and the driller gave him a dsicount on the first 60ft of well.HE TURNED THE AUGER WITH PIPE WRENCHES. 60FT.
   / Need to dig a small diameter well... #6
Deerlope,
When you started the story, I was thinking, old farmer? What did he use to turn that monstrosity? A pipe wrench. Got to the end and went yep. Hell of a man, I think I'd get bored and run out of time long before 60'.
Nick
   / Need to dig a small diameter well... #7
About 35 years ago I was working as a service tech for a company called Agway. I am sure you have heard of them. I was about 25 years old at that time and this farmer was doing a major expansion on his farm. Agway had the contract and thats how I met him.He was not real old maybe around 45 or 50. But when you are 25 that 45 or 50 looks old. I am now 61 and I think of myself as young. Glad that you enjoyed the story. Working as a service tech doing farm repairs has giving me a lot of stories to tell.By the way that is a true story. I am sure the guy has passed away but the house and building are still there.
   / Need to dig a small diameter well... #8
For 20', I would get a manual post hole digger. The auger type, not the clamshell. They come with a pipe handle. Buy 3 more sections of 6' pipe same size. Start augering. You might work up a few blisters, but it will be less work than trying to make a tractor auger go that deep & clean the hole, esp. in gravel.
By the way, dad did this, he went a good 30 ft deep. It's not that hard, only digging 6 post holes by hand.
If you are sinking a pump down the hole, make sure you use a big enough plastic shell.
--->Paul
   / Need to dig a small diameter well... #9
Dave,
You got an interesting forum going here so please let us know what you decide to do.
Fred
   / Need to dig a small diameter well... #10
I'm sure you have addressed it, but for me it's hard to imagine enough water infiltrating the 4" pipe to provide a substantail supply................chim
2016 Bobcat E85 Midi Excavator (A51691)
2016 Bobcat E85...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
1995 Vermeer 935 Towable Brush Chipper (A51691)
1995 Vermeer 935...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
