Need to dig a small diameter well...
   / Need to dig a small diameter well... #31
I always thought this could be done with a tractor PHD if you took a few things into consideration. I have installed a few wells with a small hollow-stem auger rig, and these are a few things to keep in mind.
1. You would need to pull the auger out of the hole for each extension you add. If not the cuttings will build up above the auger and you will get stuck. When designing your extensions, add a collar or something at the top to suspend it by while you add or take them off. If you drop them in the hole, it will be a problem.
2. Once you get to the top of the aquifer (saturated layer) you will no longer be able to keeep the hole open. At this point you will need to drive or jet the casing and screen down.
3. Once you get the casing and screen set, you need to seal the annular space around it. You can backfill with the clay that came out of the hole, but some places require that you cement the annular space around the casing. That brings up another point. Most states now have laws regulating the drilling of wells. While I don't like the government getting in my business, I do not want our drinking water supply contaminated by poorly designed and completed wells. You may want to check on the legalities of this.
I'd love to see pictures if anybody tries this. :)
   / Need to dig a small diameter well... #32
I wonder how the well did...that was back in 2003...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2016 Toro Sand Pro 5040 Bunker Rake (A59228)
2016 Toro Sand Pro...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
2005 MACK GRANITE CV713 DUMP TRUCK (A60430)
2005 MACK GRANITE...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
2007 Volvo VNL Truck Tractor (A56438)
2007 Volvo VNL...
