Need three point instruction
/ Need three point instruction #1
Nickthegrip
Eastern CT
I have an 08 2815 HST. I've had the backhoe attached until yesterday, when I needed to use a york rake. I got the backhoe off no problem, and went to hook up the york rake, which is when my problem occurred -
1. How do I activate the 3 point controls? I can't get the lower arms to raise/lower...
2. The top arm supplied (behind the seat) isn't long enough to reach the top point of the york rake.
I know I have to be doing something very simple wrong. I do not have a manual for the tractor, otherwise I'd look at that. I've searched all through these forums, as well as google, and come up empty.
Any detailed instruction you all could give, I would most certainly appreciate it.
/ Need three point instruction #2
Check to see if you have a control knob in front of the seat, by your feet. This controls the float of the 3 point. The upper arm should be adjustable and you can adjust to change length for different implements. It should have a nut on one end that you can loosen and then make it long or short, then tighten back.
/ Need three point instruction #3
You can read the manual on Mahindra's web site. (mahindrausa.com) "24/7 owner's care."
/ Need three point instruction #4
Did you reconnect your hydraulic hoses.
The Quick coupler hoses you removed from your backhoe when you took it off need to be reconnected back to each other to create a hydraulic loop.
Thank you for the suggestions so far - I never knew the manual was available online, that helped alot. Unfortunately I still have had no success -
If the bucket is working properly then the entire hydraulic loop is hooked correctly, no?
/ Need three point instruction #6
Not necesarily. One backhoe hose has to loop arround and attach back into the system under the right side by the tractor hydraulic distribution block.
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
