Need the facts!
   / Need the facts! #1
hillslider
MN
Kubota L3130 JD X750 and X350
I have read some posts about off road diesel and on road diesel and from what I learned from here and the places I purchase fuel there is no difference in the two except the dye.
But....there is a new place that has on road,off road and off road high sulfur. So I like saving the money so I buy the off road for use in the Kubota. Now should I buy the high sulfur or the regular? I called the dealer and they really did not know for sure. Maybe I will email Kubota. What do you all think?
   / Need the facts! #2
Hillslider,
What is the difference in price between the offroad and offroad high sulfur?
-JC
   / Need the facts! #3
High sulfur tends to have more lubricity but also newer engines are built for the low sulfur and alot of fuel manufactures add enough lube back in but theres still no spec for any diesel fuel as far as lubricity is concerned except the premium branded spec.. the only thing i can think of being a disadvantage is the higher sulfur content's tend to increase the oil's acidicity more quickly.
   / Need the facts! #4
Do a search for this topic, it is well covered. Also check Chevron and BP/Amoco for fuel spec charts. I do not have the links anymore but both can be found with a Google search.
   / Need the facts!
Well the frst couple of times there was no difference in price but this last weekend the high sulfur was 1 penny higher.
   / Need the facts! #6
Is there a significant price difference between on and off road diesel? /forums/images/graemlins/confused.gif
   / Need the facts!
Well on road right now is 1.799 and the off road I bought for the shop was 1.299. So I would say that is significant. For the shop I usually buy a hundred gallons at a time so it adds up. But even for the 10 gallons I buy for home use I save 5 big ones.
   / Need the facts! #8
It is funny your dealer does not know about high/low sulfer for your engine..... did you check the owners manual? The newer stuff sometimes has a section about that....
I asked our distributer about high and low sulfer once. And I was told that the for years, they have been decreasing the sulfer slowly. So in essece, when they anounced low sulfer fuel, it was a lable. I asked about the affect in the engines and they said it should be no affect...... It's been a while since I asked, been a few years. We run off road diesel (not sure if it's high or low).... but all the equpment runs fine.
The high sulfer fuel must be for the people who "demand" that for use in older equipment..... /forums/images/graemlins/confused.gif
   / Need the facts! #9
Hillslider,
My local suppliers don't have anything labeled "high sulfur," but others have mentioned it.
I was under the impression it was less expensive and was marketed as a "dirtier" fuel to save some money... ? But you said it cost more /forums/images/graemlins/confused.gif
Anyone else have info on this? I'd be curious to know, too.
-JC
   / Need the facts!
I checked the owners manual and all it says is to use #2 for 14 degress and above and #1 for for teperatures below 14 degrees F. One tip it did offer which I do not always do is to make sure tank is full of fuel befor parking overnight to avoid condensation in the tank. Easy enough.
Then there is a paragraph on what grade deisel fuel is according to ASTM D975????? Not sure what that means but it states fuel should have a max sulfur content of .50%. Dont mean squat to me......the pump just states high sulfur content.
I did email Kubota....will post answer if I get one.
Rob
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
2005 GMC C8500 CHASSIS TRUCK (A54756)
2005 GMC C8500...
