Need starter
   / Need starter #1
playing in the dirt
Massey 135
I have a Ingersoll 3014 with a 14 hp. Briggs Vanguard engine. I need a starter. On the Briggs site it tells me I need a # 691564 starter but this is not correct.
I have a Model 294447 , Serial # is 94070511, spec # is 0445-02 3441. Mine has a steel flywheel with a 16 tooth nylon gear on starter. It measures between end caps 4 3/8" and the drive is held on by a roll pin. Also mounting end cap is Alum cast. The #691564 is a 15 tooth starter and is shorter between end caps. Can someone please tell me what I need . Thanks.
   / Need starter #2
If you want the correct starter, then here's the man to contact.
Brian Hildreth*
Salem Power Equipment,*LLC *
6430 Napier Road
Plymouth, MI 48170
(734) 649-*‐1781
*bhildret@aol.com
salempwr@aol.com
   / Need starter
Thank you very much Hydriv for the info. I will contact him today .
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2015 FREIGHTLINER...
