Need some welding advice
/ Need some welding advice #1
HCJtractor
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I am a novice welder and have been building some simple things to help me refine my skills. I have a Miller 211 Mig. Sometimes I am running a bead and all is sizzling like it should and then "pop", the arc breaks and the glob of molten metal forms and splatters. It may pop a few times and then start sizzling again. The resulting weld is porous an splattered.
I know this is obviously operator error but what could cause this? I am using shielding gas, and have tried to have everything clean beforehand. Thanks for any advice.
/ Need some welding advice #2
Might be a bad spot in the roll of wire, can you switch rolls of wire? When is the last time you replaced or blew out the liner in the Mig gun? Could also be you changing the stick out length, and not realizing it.
/ Need some welding advice #3
i will take a guess! i think you wobble with the gun and get too much distance between it and the metal.
/ Need some welding advice #4
Sounds like what happens to me when the gas cylinder gets low. May be a problem with your regulator or hoses or something.
Are you welding inside or out?
/ Need some welding advice #5
did you buy the wire at harbor freight?
/ Need some welding advice #9
thanks, I will check all of that. Wire is good quality from Airgas.
Not necessarily. Get yourself some true Lincoln wire instead of the Airgas house brand Radnor by Harris as I recall. Yes, I know Harris is owned by Lincoln; but I suspect Airgas tells Harris to make the wire cheaper than the true Lincoln stuff.
/ Need some welding advice #10
Check the feed tension, it might be a tad loose. If the wire stops feeding momentarily it will cause what you've described.
Sean
/ Need some welding advice #11
Harris is owned by lincoln but Harris only makes Aluminum wire. They buy the 70S6. The Radnor wire on 10# spools is Lincoln Shure Arc. Made in Mexico. Good enough that you should be able to get by. Any Porrosity issue usually comes back to a Gas Issue. Can you hear plenty of gas when you pull the trigger near your ear? Otherwise a bad liner will cause the wire to stumble and weld poorly too.
/ Need some welding advice #12
Regardless of manufacturer, in my case I found the Radnor inferior to the Lincoln wire.
/ Need some welding advice #13
Just a thought from one new welder to another. I find that when I use MIG to weld and the metal is not clean enough it will spatter at me. I have found that unless I use 6011 rod with a stick welder you better clean the metal to get a good weld.
Hope it helps
/ Need some welding advice #14
That is why I dont like MIG welders. So very much can go wrong with one and very hard to find the problem. With the pop and porosity, it sounds like bad wire.
/ Need some welding advice #15
Up here in canada, air liquide blueshield brand is very commonly used. Made in canada.
/ Need some welding advice #16
Gary if you think that is tough, try diagnosing someone's problem with a Mig welder via the Internet.
A lot easier when you can see it, and listen to it in person.;)
/ Need some welding advice #17
/ Need some welding advice #18
I hear this complaint from some of our "limp wristed" customers, who either hold the torch too loosely and it pushes off and creates an irregular arc, or the torch is held too far off the metal.
/ Need some welding advice #19
You didnt state at what amperage and lenght of time welding that this happens, but i will throw this out for thought. If you exceed the duty cycle of the welder you will get this type of behavior. Other than that, all the other ones that would cause this have been stated.
/ Need some welding advice #20
Probably not your problem, but have you changed the tip, and cleaned-out the end? Sometimes buildup can prevent the gas from flowing correctly
Unused Hustler Euro Style Loader Kit (A66734)
Unused Hustler...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
235/85R16 Tire (A68134)
235/85R16 Tire...
PALLET OF HOSES (A68842)
PALLET OF HOSES...
2012 Mercury 25HP Outboard Boat Motor. (A66738)
2012 Mercury 25HP...
