Need some help with Kubota Models...
/ Need some help with Kubota Models... #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
I have a Kubota B7800. This size of the B -series works for me.
What I would like to know is if Kubota made a B-series tractor
with upgraded features and more lift capacity, front and back?
Also, I would like to stay with a Tier 2 machine. Not sure when
the B-series changed to Tier 3 and 4??
/ Need some help with Kubota Models... #2
When I want to see the differences - ESPECIALLY with the B series Kubotas I look on tractordata.com. Maybe there's some logic to the size or HP in relation to the model numbers that I missed on the older tractors. At least in recent years, many models have the HP as part of the model number.
/ Need some help with Kubota Models... #3
The next size up B models were the 3200/3300 and now the 2650/3350.
For a new machine, the 2650 is what you'd want if you want to avoid emissions. Anything 26HP and below can meet Tier 4 Final without the new emissions controls.
Prior models were Tier 4 Interim and also met standards without the new controls. None of these tractors would have been Tier 3, as that was for high HP machines (75HP and up if I remember right). Tier 2 was prior to 2007, so you're not going to find anything new that's Tier 2.
Looking at the B2630 and the B3030.
Looking at the specs, both models have the same lift capacities front and back, and
the same break out force. What will I be missing on the 2630?
/ Need some help with Kubota Models... #5
OK, yeah those were older "deluxe" B models, predating the 2650/3350. Very good machines.
Any feed back on going with the 2630 at the lower hp?
/ Need some help with Kubota Models... #7
You know what, look in some of the more recent 2650/3350 threads, where this exact thing has been discussed. For my purposes 26hp would be ok most of the time, except for running certain things on the PTO. If you need more PTO power, then go up.
I'm getting differing information when I read various threads.
Can anyone tell me if the B2630 has greater lift capacity (both front and rear pto) that the B7800?
And, does the the B3030 have greater lift capacity than the B2630?
Are there any additional features found on the B3030 that are not on the B2630?
What are the differences between the la402 and la403 loaders?
This will be very helpful-thanks!
/ Need some help with Kubota Models... #9
tractordata.com has most of the answers if you dig a little.
/ Need some help with Kubota Models... #10
Here's some scans from an old brochure I have - approx 2007. Maybe they will help.
/ Need some help with Kubota Models... #11
Aside from the larger engine and HP, 4 cylinders vs 3, more weight, I believe they were identical tractors. No difference in physical size, height, wheelbase, etc. Also, the B3030 had a cab model available while the B2630 did not.
/ Need some help with Kubota Models... #12
According to my dealer, when I was looking at B Series, the 2630 didn't sell well so he never kept them in stock and they were dropped when they introduced the B3000, gets kind of confusing.
/ Need some help with Kubota Models... #13
Thanks to guys like von-mil and Tractordata.com you should be able to tease out some answers. Interestingly, my old L3130, with the lLA723 loader and 31 hp sure had a lot more loader size and lift than our newer L3400 with 34 hp and the LA463 loader. Hp isn't everything, except speed and PTO potential.
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
MAC Hi Power Towable Generator (A65579)
MAC Hi Power...
2005 CATERPILLAR 416D BACKHOE (A65053)
2005 CATERPILLAR...
2016 Jeep Grand Cherokee 4X4 SUV (A64557)
2016 Jeep Grand...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
