Need Some Help With 445A Bucket Auto Level Rod Measurements
   / Need Some Help With 445A Bucket Auto Level Rod Measurements #21
That is the place for the starter. It looks nice but has no names or numbers on it. Sure cranks good though and low current draw. The pins on mine are 30mm, I searched around and found some 1-3/16" which is slightly larger , I used 4140, and touched up with a hand reamer. The cylinder rebuild kits are readily available and are metric of course. I will park mine inside so starting won't be a big deal, but my drive on the old starter was bad so I could resist trying the PM upgrade.
I don't if they still operate that Dagenham plant or not.
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
DEUTZ MARATHON...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
2019 FREIGHTLINER SD122 DAY CAB (A57880)
2019 FREIGHTLINER...
