Need some help identifying some threaded fittings
   / Need some help identifying some threaded fittings #1
chris the wrench
Chinook Pass
Kubota L3902 & BCS 853
Finally had some time to work on my diy rear remotes and top cylinder for my box blade. I got the tractor end of everything installed and working! That was a fun learning experience. I've worked on all kinds of engines, but have only a little bit of hydraulic experience and most of that was swapping obviously broken components.
I need to either extend(about 12") or purchase longer hoses for the cylinder. I'm trying to determine what threaded fittings I have on my existing hoses. The banjo end doesn't really need to be a 90 degree for my setup.
Are those BSPP fittings?? Or am I totally off? I'll probably head into town tomorrow to see what the hydraulic shop has to say, but my curiosity can't wait till then!
From the amazon listing for the cylinder "Technical specifications: Connection: 12-L bulkhead size 3 (usual coupling connector), 18-1.5 SW22 nipple + union."
Thanks
Chris
   / Need some help identifying some threaded fittings #5
Beat me to it. The document is available on Discount Hydraulic hose website also, in case you don't have the saved PDF handy. It does take a little poking around to find it, but not bad.
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 KOMATSU PC88MR-10 EXCAVATOR (A60429)
2018 KOMATSU...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
Zero Turn Mower (A59231)
Zero Turn Mower...
