Need some help identifying some threaded fittings
   / Need some help identifying some threaded fittings #1
chris the wrench
Chinook Pass
Kubota L3902 & BCS 853
Finally had some time to work on my diy rear remotes and top cylinder for my box blade. I got the tractor end of everything installed and working! That was a fun learning experience. I've worked on all kinds of engines, but have only a little bit of hydraulic experience and most of that was swapping obviously broken components.
I need to either extend(about 12") or purchase longer hoses for the cylinder. I'm trying to determine what threaded fittings I have on my existing hoses. The banjo end doesn't really need to be a 90 degree for my setup.
Are those BSPP fittings?? Or am I totally off? I'll probably head into town tomorrow to see what the hydraulic shop has to say, but my curiosity can't wait till then!
From the amazon listing for the cylinder "Technical specifications: Connection: 12-L bulkhead size 3 (usual coupling connector), 18-1.5 SW22 nipple + union."
Thanks
Chris
   / Need some help identifying some threaded fittings #5
Beat me to it. The document is available on Discount Hydraulic hose website also, in case you don't have the saved PDF handy. It does take a little poking around to find it, but not bad.
iDrive TDS-2010H...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
Utility Cart (A59231)
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
