Oil & Fuel Need some help!! 4300 stalling!!!
/ Need some help!! 4300 stalling!!! #1
PGDiesel
John Deere 4300
Hey guys!! New poster here and I need a little technical help!! I changed the fuel filter in my JD 4300 hydrostat last week for the first time... Tractor ran GREAT before the change. However, I almost never got the tractor to start after the change!! Now, the tractor will start but runs extremely rough. As I put it in gear, it may move 10 ft, and then cut off... as if it is losing fuel.
Do I have air in my diesel lines? How do I get this out? I have tried letting it run to try and get the air out, but the engine will stall out almost to the point of dying, then get a burst of fuel and shoot up to about 1800 rpms. Then, die back down, and shoot back up again. If I try to engage PTO or drive the tractor, the engine will die... Any thoughts?? Again, it ran great without any problems prior to this fuel filter change... So much for preventive maintenance!!!
/ Need some help!! 4300 stalling!!! #2
Sounds like you already figured it out.... could still be some air in the lines. At least, changing the fuel filter was the only thing done to the motor before the problem started.
You will need to spin the motor over and crack open the lines to the injectors one at a time, just enough to bleed the air out of each one. The repair manual will tell you the exact procedure, if you have it.
Thanks Kebo...
I will give this a try... Unfortunately, I do not have the repair manual, only the owner's manual. Should I open the three lines (hard lines) going directly into the pump (ie, at the top of the injectors)? Do I loosen them until fuel flows out?
Your help is greatly appreciated!!!:thumbsup:
/ Need some help!! 4300 stalling!!! #4
This systems are self-bleeding, I am betting the seal on the filter or bowl is missing, damaged or leaking and it's sucking air.
/ Need some help!! 4300 stalling!!! #5
Could the fuel shut off valve not opened all the way back up and is choking fuel? I'd pull the filter out and inspect what you have going on.
/ Need some help!! 4300 stalling!!! #6
Do you see a little lever by the fuel filter? If so start pumping it till it gets hard to move.:)
/ Need some help!! 4300 stalling!!! #7
I don't think the 4300 has this. At least I didn't see it on mine when I changed the filter a few weeks ago. Just had to start it a few dozen times to get the fuel back into the injectors.
Thanks guys... Good info here. Actually, I called the local JD store and asked them a couple questions about my problem.
My tractor does have the lever on the side of the fuel pump. According to the JD tech, some of those tractors had a lever, while most did not. (evidently there was a design change around this time) I pumped this lever about 50 times without much success. Interestingly, on the first pump, it feels like it is pushing fuel through the pump, but there is little to no pressure on successive pumps. The tech told me to pump that lever and to just keep running the engine to get the air out of the lines. It would run rough for a while, but would smooth out after about 30/45 mins. May just be me, but it doesn't sound healthy to do that!!
I have checked the fuel shutoff valve and it is in a vertical (open) position. I do have a fuel leak on the petcock at the bottom of the fuel tank, but I doubt this would cause issues getting air into the fuel lines. I am replacing the petcock today.
I'll open the filter/sediment bowl back up to make sure it is sealed... then loosen the hard lines around the injectors to bleed any excess air. This is supposed to be a self-bleed system, so I am a bit stumped...
Thanks again for all the help!!
/ Need some help!! 4300 stalling!!! #9
Think about checking out the fuel supply system starting from the bottom of the fuel tank. Make sure you have a positive flow at every stage.:)
case 370 glass door never installed (A61307)
case 370 glass...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
iDrive TDS-2010H...
