Need snow removal tractor advice
   / Need snow removal tractor advice #1
hawk258
looking for one
Looking for inexpensive options for snow removal machine for 300 foot concrete driveway that is on a slope with a drive across bridge at the bottom going over a creek. Need ideas for something reliable, works well, easy to operate and drive, won't flip over and isn't huge. My 15-year old son will likely be using.:) Thanks - Single mom tired of shoveling snow - any advice would be greatly appreciated! bearpittsburgh@aol.com
   / Need snow removal tractor advice #2
Welcome to TBN. :)
   / Need snow removal tractor advice #3
u have many options u have the snownblower u can get a snownblower in front of your lawn tractor u can get a tractor whit a blade u can get a truck whit a plow on it theres many things out there for the hard winter all depends on your budget
   / Need snow removal tractor advice #4
Are you thinking about a walk behind or a riding mower?
   / Need snow removal tractor advice #5
If your vehicle is 4WD, adding a plow might be your cheapest, safest and most reliable method.
If you don't have a 4WD vehicle, a lawn tractor with a front blade or snow blower might be a good choice. You can buy new, which would probably the most reliable way to go, or buy used (look on Craigslist) for less money...but those can be a gamble.
Although you don't see the lake effect snows like Erie, Pittsburgh does get hit pretty hard on occasions. Any lawn tractor based removal is going to be of limited value in an accumulation exceeding 4 or 5 inches.
How much of a slope? You'd probably want chains on the rear tires, at minimum.
How have you been removing snow on this drive in the past (or is this a new home for you and your son)?
Personally, I'd go for the plow on your 4WD vehicle, if you have one and learn how to install and remove the plow.
Good luck in your decision, Hawk258!!
   / Need snow removal tractor advice #8
Also where you live is a big factor as snow conditions vary a lot.
Look at her e-mail...pretty sure she's in Pittsburgh, PA
   / Need snow removal tractor advice #9
Perhaps a little more detail on budget would be helpful.:)
A walk behind snow blower may be one of the first items on the inexpensive list.:)
   / Need snow removal tractor advice #10
Agreed. A moderately-long drive, and sloped, in an area with ample snowfall may not permit another "inexpensive" option. A used Honda, with tracks, would be my suggestion.
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A52472)
MCELROY 500 SERIES...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
