Need simple, durable bridge ideas
   / Need simple, durable bridge ideas #21
crbr said:
I know a guy that found a set and placed them over the edge of an embankment (that he dug out). Access from the lower side of the embankment gave him access to under a vehicle, where the vehicle drives onto the ramps from the top side. That was his answer to a lift.
That is exactly what the old timer I bought mine from used them for. Set some railroad ties in a ditch to support one end and the other end on the ground. Gave him a place to get under a vehicle and change oil.
MarkV
   / Need simple, durable bridge ideas #22
I done the same thing. I can drive fourwheelers, tractors, and even my truck over it. Costed me about 150bux.
   / Need simple, durable bridge ideas #23
Currently working on a bridge with pine logs. I have 2 trees used as stringers about 30 inches in diameter and about 30 feet long. I had to increase my height from the water since my initial trial was iced over this past winter (good thing it wasnt finished). Im going to use 1 set of 2x10/12 to tie the stringers together and then run 4 2x12 length wise across the bridge.
One side sites on rocks, the other is just on the bank. I figure by the time the pine craps out, Ill replace it with steel.
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
2007 GMC 2500HD (A56435)
2007 GMC 2500HD...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
