Need shaft for 14t baler rear yoke snapped
   / Need shaft for 14t baler rear yoke snapped #1
dairythings
I am looking for a john deere 14t baler part (yoke rear)
Parts number BP14507E
email me at : dairythings@gmail.com
our baler snapped this part and we cant seem tofind one that will fit
the u joints. this is a 1"x1 1/8" square shaft with hole in the neck.:confused::confused:
   / Need shaft for 14t baler rear yoke snapped #2
This is a tough one, the bearing cross measurements are 1" @ the bearing caps and 3.150 width. Not sure where you will find those dimensions and still be a square / rectangle hole on the yoke. Worst case lob off the other end and get 2 cat 6 or cat 12 yokes one for the sq shaft the other for the powershaft pipe. Here is an example for cat 6 in JD#s
pm700-0600 (1" x 1 1/8")
pm701-0600 (1 1/2 tube size w/ .065 wall) (better compare to original tube
pm200-0600 (bearing cross)
All items should not be over about $55 before your labor, good luck
   / Need shaft for 14t baler rear yoke snapped #3
There's a seller on eBay who is parting out a 14T. Look for the guy selling some needles for one and then look at the ad. He can probably get you everything you need.
   / Need shaft for 14t baler rear yoke snapped #4
Sent you a PM. Ken Sweet
   / Need shaft for 14t baler rear yoke snapped #5
Do you still need the shaft with yoke? I have some 14Ts I am parting out. If you still need one, get me the yoke demensions and I wil see what I have.
Honda EM7000iS 7000 Watt Inverter Generator (A50322)
Honda EM7000iS...
2022 Weber CR5-II HD Reversible Plate Compactor (A50322)
2022 Weber CR5-II...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
2015 Nissan Altima Sedan (A50324)
2015 Nissan Altima...
2006 Volvo VNL (A52748)
2006 Volvo VNL...
