Need shaft for 14t baler rear yoke snapped
   / Need shaft for 14t baler rear yoke snapped #1
dairythings
I am looking for a john deere 14t baler part (yoke rear)
Parts number BP14507E
email me at : dairythings@gmail.com
our baler snapped this part and we cant seem tofind one that will fit
the u joints. this is a 1"x1 1/8" square shaft with hole in the neck.:confused::confused:
   / Need shaft for 14t baler rear yoke snapped #2
This is a tough one, the bearing cross measurements are 1" @ the bearing caps and 3.150 width. Not sure where you will find those dimensions and still be a square / rectangle hole on the yoke. Worst case lob off the other end and get 2 cat 6 or cat 12 yokes one for the sq shaft the other for the powershaft pipe. Here is an example for cat 6 in JD#s
pm700-0600 (1" x 1 1/8")
pm701-0600 (1 1/2 tube size w/ .065 wall) (better compare to original tube
pm200-0600 (bearing cross)
All items should not be over about $55 before your labor, good luck
   / Need shaft for 14t baler rear yoke snapped #3
There's a seller on eBay who is parting out a 14T. Look for the guy selling some needles for one and then look at the ad. He can probably get you everything you need.
   / Need shaft for 14t baler rear yoke snapped #4
Sent you a PM. Ken Sweet
   / Need shaft for 14t baler rear yoke snapped #5
Do you still need the shaft with yoke? I have some 14Ts I am parting out. If you still need one, get me the yoke demensions and I wil see what I have.
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52748)
NEW 2025 Load...
2008 Saturn VUE SUV (A50324)
2008 Saturn VUE...
Club Car Carryall 500 (A50121)
Club Car Carryall...
